Question about RCA Televison & Video
I have rca with the fl231 problem i repppplaced the fuse and it work for about 30min then i turned it off and heard and small pop and the tv would not turn back on what do i look for now
  • RCA Master
  • 1,525 Answers
Hello the fuse has pop again. id check the diodes first then the transistors check capacitors for any swell on them good luck
shaun
Posted on Jul 31, 2009
Replaced the fl231 fuse tv worked for day now blown again and tv keeps shutting off what do i check now
Resolder the flyback pins as thats what causes the FL231 fuse to blow. Soldering the flyback should solve the issue you may need to replace the fl231 again
Apr 28, 2011 | RCA R52WM24 52" HDTV Projection Television
Does the rca 52950 have the fl231 fuse? If so where is it located? If not which fuse controls the convergence. I fixed my newer model tv with the fl231 fuse but I dont see it in this tv.
no the fl231 fuse is only for model itc222 rca's . these older set unfortunately do not have that fuse convergence is contolled by a sepreated cuircit board. also these set have no stk ics that are common for most set that control convergence. it uses a series off transistors.
Jan 03, 2011 | RCA P52950 52" Rear Projection Television
Cant find convergence in setup
There are three small rectangles sqaure boxes cap fuses parts(FL231) the one in the middle is dead.Replaced the one in the middle located right side near of the big black block of plastic call FBT.U know how to do soldering and have the equipments?Try website like Ebay.com to the cap fuse part(FL231) fuse.After the cap fuse(FL231) is replaced the Convergence well return,ur tv back to normal.
May 28, 2010 | RCA D52W136D 52 in. TV/DVD Combo
Convergience not working, three color pictures and concaved top and bottom. Is there a module that I can replace?
Check the small brown fuse FL231 located just to the lower right of the flyback. There are 3 small brown fuses. The middle one is FL231. Most likely it is blown. The reason it blows is because of the lead free solder used on the new boards. If you turn the board over you will probably find cracked solder joints on the flyback terminals. Re-solder all of the flyback terminals and replace the fuse if it is blown. This fuse tells the TV that it is a rear frojection TV and not a standard CRT
Feb 08, 2010 | RCA HD52W59 HDTV Projection Television
I have color misaligned in my RCA HD52W59 tv. I can see three different colors yellow, blue and red. It is intermittent issue. Please What is the best solution for that?
Go to menu then setup if you do not see convergence in the menu then you have a Blowed Fuse FL231 its on right side of FBT flyback transfomer will be 3 small brown looking caps But are fuses it will be the one in the Middle! Go to Partstore.com Look for FL231
Dec 03, 2009 | RCA HD52W59 HDTV Projection Television
We have three separate images in red green and blue on our RCA projection TV. How do I fix this???
WHEN YOU GO TO MENU IS CONVERGENCE ON MENU IF NOT YOU HAVE OPEN FUSE FL231 IT IS LOCATED ON RIGHT SIDE OF FBT-FLYBACK TRANSFOMER ON DEFLECTION BOARD ,there is 3 of them they are small brown rectranigle it will be the one in the middle fl231.
May 19, 2009 | RCA R52WH73 Projection Television
FL231 Fuse Post
the fl231 problem is unique to the rca itc222 chasis the model mm52100 is not this chasis. wackey? describe the picture. You may have a solder problem or a compnent overheating.
Jan 14, 2009 | RCA MM52110 52" Rear Projection HDTV-Ready...
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
Convergence
Open Fuse FL231 will cause your problem.
Aug 06, 2008 | RCA HD52W66 Projection Television
RCA 52w59 projection fuse fl231
Instead of taking the board out, I just soldered two wires to the old fl231 fuse on the underside. Installed a fuse holder with a half amp fuse. And I re-soldered all of the flyback points. My tv is working like new. thanks for everyone's help.
Dec 28, 2007 | RCA HD52W59 HDTV Projection Television
Televison & Video Logo
64 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
