Question about Maytag MDB9750AWS Built-in Dishwasher
Turned breaker off then back on now dishwasher has no power
  • 10,865 Answers
Turn the breaker all the way off again. And then back on again. You should have power now. IF turning the power back on caused the breaker to kick off you may have a short in the breaker itself.
If you are handy you can change the breaker your self for the cost of a replacement breaker, usually under ten dollars. Then you will know for sure that where the problem was or is.
Posted on Jul 31, 2009
Resetting computer on kdte204dss0 Kitchenaid
The most common reset for the dishwasher is:
1. First, unplug the dishwasher power cord or turn the circuit breaker off for 30 seconds.
2. Then, plug the dishwasher power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
3. After that, press the Pause / Cancel / Stop button twice to clear the display.
4. Finally, start a short cycle, to check operation of the dishwasher, by selecting a cycle and pressing and holding the start button until the dishwasher starts.
Jul 28, 2016 | KitchenAid Dishwashers
Our machine is frozen not responding to panel buttons
You can try resetting your dishwasher.
Jul 28, 2016 | Dishwashers
Had a power failure from bad weather now the dishwasher is dead? checked the fuse box the breaker is fine, there are no lights on the display panel. what is the reset procedure for this dishwasher?
Try turning the breaker for the dishwasher off for 30 seconds and turn it back on. This should reset the dishwasher control board. If it still doesn't work then most likely the power failure burned up the main control board. The control boards in the newer dishwashers are sensitive to any type of power surges or failures.
Hope this gets it running for ya.
Dec 15, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Miele G 2630 stopped working. It started and then just stopped now no power
Hi
The power issue with the Miele G2630 dishwasher is due to a blown fuse inside the dishwasher or due to faulty main board of the dishwasher. However, before checking internal components we can first reset the circuit breaker, make sure it is a 15 A breaker. If the breaker is fine then you'll need to disassemble the dishwasher. Try and dis-mantle the dishwasher from its place, before this remember to turn off power and water supply. And also check for the drain hose. After the dishwasher is dismantled, you can remove the back panel of the dishwasher and check for the blown fuse and also check for any loose connections on the power supply board. Inspect for burnt components on the main board.
Please post back for any further assistance. If you are satisfied please do accept the solution.
Daniel
Jul 30, 2010 | Miele G2630SCiSS Dishwasher
D/w quit when garbage disposal drain clogged,, now I have no power lights and nothing ,,, no breaker are blown.?
you might try resetting the breaker(turn it off then back on) I would wait, say 5 min before turning breaker back on to see if it resets the microprocessor on the control module.
Dec 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Wont go through cycles or drain the 3inches of water.Is getting power
turn on the dishwasher then go to your circuit breaker and, switch off the power to your dishwasher next: reach in to your dishwasher and remove the cover on your pump then remove any broken glass etc. that has fallen into the pump then put the cover back on and, close the dishwasher turn it on and, turn on the breaker you turned off earlier your machine should work again let me know how it goes...
May 02, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Power went out and when cut back on the dishwasher is beeping
Did you check the breaker that controls this device.....and there may be a rest on the unit...also turn of the breaker and turn it back on as well unplugging the the DW and plugging it back in.
Hope this helps...The Fang
Mar 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Feb 05, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
GE Triton not working
Jitterbugclu-
I may have the solution. Husband just turned off power to dishwasher via circuit breaker. Waited around 30 minutes.
Restored power and Triton came back with normal lights.
I just ran a cycle and all was well. Hope this helps you.
My fingers are crossed because I don't know what happened but did read on another site that this should be the first thing you try before expen$ive repairman.
Reply back if it works!
TootieC
Dec 25, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Just had a power outage, dishwasher is dead
althought e breakers apear to be on physcally turning them off and then back on especcially after power flashes(the breaker might of partially tripped, and needs to be reset(possible)
Mar 16, 2008 | Frigidaire PLDB998A Built-in Dishwasher
Maytag MDB9750AWS Built-in Dishwasher Logo
125 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
