SOURCE: System settings on Sharp AR-M205
Found a very good solution...Use Adobe Acrobat to do the scanning. Launch Adobe Acrobat and select the AR-M205 as your scanner and proced from there. Adobe will pull up the Sharpe software to do the actual scanning but Adobe will be in charge and create a pdf file. I am using Adobe 6.0 which is not one of the free versions, I think.
SOURCE: Sharp AR-M205 is not working with windows vista home edition
1. Uninstall the previous driver
2. Re-install the driver ( do not connect the usb cable at this time )
3. After driver installation, the pc will ask you to connect the usb, do this and it should be OK
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
SOURCE: H2 Error Message on AR M205 Sharp Copier
hi..there is a problem in the thermistor,thats why you
get the error code as H2.
check this out..
thank u..
kindly rate my response..
SOURCE: Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
