Question about Bosch Axxis WTA 3510 Electric Dryer
How do you replace the bulb inside the drum - Bosch Axxis WTA 3510 Electric Dryer
  • 82 Answers
There is a clear plate inside the drum remover this and replace the bulb spare bulbs u can get from espares
Posted on Jul 31, 2009
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
How do you replace the Frigidare gas dryer model FDG546RES2 interior light>
On that model the drum light is in the top of the inside of the front panel. Their is a sheild over it held in by a screw,while that i dont know for sure i believe that screw is phillips headed. remove that screw and the shield should come right out. the bulb is a nightlight type bulb.
Gene
Aug 06, 2011 | Frigidaire FDG546RE Dryer
Frigidaire Model NMER336FS0 How do I change the interior light bulb in the drum?
Unplug the dryer first, of course. With a putty knife, locate the clips under the front of the main top to release the spring clips. Lift the top and support it open. Disconnect any wire clips that are attached to the front panel, such as the door switch wires or wiring harness. There may be a zip tie attached to the wiring harness that you have to remove simply by cutting it off. On the inside, remove the front panel mounting screws down along the front inside edge of the panel. Pull the front panel up and out to remove. Disconnect the wires from the light bulb, carefully noting which wires go where, and press the release tab to remove the old light bulb housing. Install the new bulb and assembly by inserting it into the front panel and snapping it into place. Reattach the wires. Replace the front panel by aligning the slots at the bottom of the panel with the support clips. Lift on the front of the drum as you snap the front panel into place. Replace the panel screws and reattach any wiring that you disconnected to remove it. Rotate the top back into place, pressing down on the front to secure the spring clips. Plug it back in and voila! Good luck!
Jul 16, 2011 | Dryers
Where is the light bulb located ?
what model # ? most are inside the drum area - put head in (with machine off) and look around for a plastic cover. behind that is the dead bulb.
Dec 17, 2010 | Maytag Dryers
I have gas dryer, model SDG4606, and the light inside drum does not work. How do I replace it?
When you open the door on your dryer your light bulb is located at the top of the opening. There will be a clear plastic cover over it that is held in place by one screw. Remove the screw and allow the cover to hinge away from the opening. The bulb is Maytag part number 67001316.
Sep 17, 2010 | Maytag SDG4606A Gas Dryer
Change bulb
I wish I knew for sure, here is a picture :
http://www.repairclinic.com/SSPartDetail.aspx?s=t-FEQ1442ES-%3d%3dc253i780103&PartID=780103
It may need a appliance bulb. Good luck.
Jan 29, 2010 | Frigidaire FEQ1442ES Electric Dryer
How do I change the electric bulb inside ????
First of all, unplug your dryer from the plug. Then open up the door, and look directly to the back of the drum and you should see a rectangular cover with a phillips head screw. Unscrew, remove the cover, and then unscrew the bulb. Make sure you replace it with the same bulb. Usually, they're 10w appliance bulbs. I hope this works for you, but if not - feel free to contact me again. Good Luck!
Jan 13, 2010 | Bosch Axxis WTL 5410 Electric Dryer
Kenmore 110.84821300
The rythmic rubbing sound you are hearing could be coming from a few sources. It could be drum support rollers that require lubrication, bulkhead screws that have come loose, the drum seal not seated properly, or a silencer plate that has come off the compartment side and is rubbing on the drum.
First, look inside the dryer along the seam where the drum meets the front and rear of the dryer. You should not see any part of the felt drum seal protruding inside the drum. Sometimes the seal starts to come loose or becomes misaligned and sticks through inside the drum. This will cause thumping and excessive noise. If you have anything caught in the drum seal (i.e., a screw, change, etc.) this can also cause excessive noise.
Remove the dryer top panel and start the dryer and watch for anything obvious rubbing on the drum. The top comes off by removing the screws in the rear and sliding the panel back, then up. (CAUTION: DO NOT get your hands around the drum while it is rotating and any of the electrical connections). Look for any vibration from from the rear bulkhead (this is the back wall of the dryer where the drum rides against). Sometimes the screws holding the bulkhead to the cabinet come loose.
Another thing to look for is a metal silencer plate that is usually mounted along the side panels. This plate is glued on and is used for noise reduction. Sometimes it comes off and will rub against the drum.
If everything checks out good, remove the lower panel under the door by removing the screws under the bottom edge (HINT: Placing a small block of wood under the front feet of the dryer can make this easier). The panel will drop down then come off. If it gets stuck, tap on either side to knock it loose. Start the dryer again and look/listen for any noises coming from the drum supports. The drum rides on the drum supports and they require periodic cleaning and lubrication.
The drum light could be a lamp socket problem and/or wiring. Make sure you are using the correct bulb as well. I believe the bulb is only supposed to be a 25W bulb. This isn't related to any long dry time problem.
The heat problem could be directly associated to clogged dryer ducting. If the dryer is full of lint when you open it, you will have to thoroughly clean the vent ducting and interior cabinet. NOTE: This is a fire hazard!
Some things to try: Remove the dryer exhaust hose and start the dryer. The air leaving the back of the dryer should be forceful and hot (about 140 degrees F). If the air flow is weak and cool, you have a clog INSIDE your dryer. If the air flow is normal, check the vent ducting from where it leaves your dryer to where it exits your home. The dryer ducting should be cleaned routinely and kept clear of obstructions.
Your heat problem may not be a component at all. Double check your dryer interior and ducting and let me know what you find. I hope this helps you.
Apr 10, 2008 | Dryers
Replacing light bulb on dryer
Light is located just above the door on the inside of the drum. It has a clear plastic lens on it. The lens has a hinge on the top and a retention feature on the bottom. You can see all of this with a mirror. Simply push the button up and the lens will swing up. You can then access the light bulb.
Oct 27, 2007 | Dryers
WHIRLPOOL DUET DRYER
I had the same problem. I found out that the door switch (switch that is pushed in by the door when it closes to tell the machine that it can switch on ) had blown. It costs about $16 for a new one. You have to open up the casing but then you just unplug the old one and plug the new one right in. My light still doesn't work but I never really saw the point of it anyway.
Oct 15, 2007 | Whirlpool GEW9250 Electric Dryer
Bosch Axxis WTA 3510 Electric Dryer Logo
119 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
