Question about Maytag Legacy Series Top Load Washer
Belt broke how do i get the pump off i removed the 3 torq screws
I pulled the motor and pump put on a new belt and a new pump the pump was leaking on the belt
Posted on Aug 18, 2009
Died while driving
does the motor crank or is it dead ?
Feb 12, 2013 | 1992 Subaru Loyale
Not spinning, and buzzing sound
F02 is the code for long drain. The first thing to do is check the pump filter. Remove the lower panel by removing the 3 torq screws, the panel will come off. Right in front will be the pump filter. Remove the cap and pull the filter out. Clean out any lint and/or debris. See that you have some low basin to collect water, or some towels when the filter is opened. Or take the rear drain tube from the wall drain and lower it to basin or bucket. (The drain pipe must be fitted back in the SAME position) The spin will not work when your filter or pump is blocked.
Nov 26, 2007 | Whirlpool GHW9250M Front Load Washer
How do you remove water pump from it"s housing!
When removing the pump unit with special tool (some auto-parts stores rent them), TURN CLOCKWISE TO LOOSEN the pump-unit, counter-clockwise to tighten. The Torq Specs for the pump-unit is: 73 Foot Pounds. There are stop tabs on the pump-unit that mate with the tab stoppers on the main water pump housing unit. I had to re-torq by visually viewing where the stop tabs where after the first torq, don't over-torq or you will bend the tab stoppers on the pump unit. ALSO...the water pump-unit front cover requires a new rubber gasket (you'll have to order it through GM or use RTV silicone under the old gasket, which has a grooved fitting inside the front cover). The Torq Specs for the front cover (5 bolts) and water neck cover (2 bolts) is: 89 Inch Pounds. Those small bolts tighten normal, clockwise.
Read more: http://wiki.answers.com/Q/How_do_you_replace_the_water_pump_on_a_1999_Oldsmobile_Aurora#ixzz1CeLdWsjN
Jan 30, 2011 | 1998 Oldsmobile Aurora
Hello! The belt broke on our Amana Mod.# DLW330RAW . Could you explain how to install the new belt? Thanks Ron
Remove the bottom kick plate.
Remove 4 big bolts and unplug the motor. Move the motor assembly to a work bench. You need a T-20 torx driver to remove the pump screws and remember the rear pump leg goes between the belt. I have your Amana washer repair manual HERE
Mar 17, 2010 | Amana DLW330RA Top Load Washer
Amana lw8252w2 changing belt
there are 3 screws that hold the pump to the moter but sometimes it is rusted so you may need to pri it off
Nov 29, 2008 | Amana ALW480DA Top Load Washer
Lwd70aw washing machine water pump
your pump been leaking water and has the pump rusted to it ,,,,, if the clips are removed the you will just have to pry and break pump loose to remover ,,,, clean the motor shaft good before installing new pump
Oct 16, 2008 | Kenmore 24032\24036 Top Load Washer
H/F code
Smitty, remove the bottom panel, 3 screws, they may be torqs. The panel will drop down and off. The filter will be right in front. Get a flat pan or a bunch of towells handy when you unscrew the cap. Catriver.
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Belt Removal and Replacement
No.  The motor and pump assembly need to come off.
   There is 4 1/2 inch bolts that hold this assembly to the main mechanism.  2 on top and 2 on bottom.  Work belt off bottom pulley on transmission and then remove these bolts.  Turn motor over and remove 3 torx screws holding pump to motor.  Install new belt then reinstall pump with 3 screws.  Reinstall assemblt to mech.  Pu top 2 screws in first then bottom 2.  Be sure belt goes on left side of black plastic idler pulley.  Work belt around transmission pulley.  You can press on opposite end of idler pulley arm to loosen belt tension.  Make sure belt is on all pulleys before testing.
Oct 18, 2007 | Amana ALW480DA Top Load Washer
Changing belt on washing machine, that broke
to change the belt you need to remove the pump attatched to the motor. the pump is held on by either spring clamps or in older models, torx (star) screws. I believe the size for the torx screws is #20. slip the belt over the motor pulley and around the tension pulley and finally around the transmission. reinstall the pump and you're good to go.
Aug 18, 2007 | Amana ALW540RA Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
