Question about Grinders
I just got a 6" bench grinder from ace hardware at a garage sale. does anyone know how to put this thing together?
  • 832 Answers
Are this dismantled? Normally it comes with a cord with
plug already in place. All you have to do, is plug it to the
outlet, and switch the power on.
Posted on Nov 06, 2009
How do I operate bench grinder?
A murphy, A bench grinder must be used with a lot of caution and respect while using this equipment, Check the attached links,instruction and guides, Good luck work safe.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
OSH Answers Fact Sheets
Pedestal Bench Grinder Safety
Bench Grinder Basics
Mar 21, 2016 | Bench Grinders
Lights dim
if the grinder just hums then it is a 240 volt unit and will burn out on 110 volts
the garage power should be the same as the house 240 v
but if only 110 v that indicates that it is 1/3 of a 3 phase power supply
if it has just started then get a electrician in to check the reason for the power drop
Jun 26, 2015 | Heating & Cooling
Starting coil switch I had to replace a bearing on my buffalo bench grinder and I cant figure out to put the starting coil switch back on or how it works
A coil is just that a coil and unless it has diodes it doesnt matter how you put it on. let me know (diodes are those things that are usually black with a silver stripe -cylindrical in shape)
Jun 23, 2011 | BUFFALO Grinders
I have a Buffalo B-10CB(CH) bench grinder and the on/off switch has broken, it's a push/pull type. What can I replace it with to make it work safely?
You could connect the wires of the switch together inside and bypass the switch. Then I would connect in the power cable a switch rated for 1 hp. You can use surface mount electrical box, with two cable connectors (one for the cable going into the grinder, the other for the cable going to the male cord end of the cable. Install a 120 volt switch inside the box (similar to the light switch in the wall). Make sure that the switch is rated for 1 hp. I would install the switch under the bench, under the grinder.
Joe
Feb 28, 2011 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
Cant get a on off switch anywhere co that maid it for wilton is out of business what a scam.
Repair parts have always been a problem.
See if you can get into the electrical area ... open the bench grinder from underneath ... tie the switch wires together ... put a regular wall switch on the electric line.
I hope it works for you.
Oct 21, 2010 | Wilton 17202 8" Bench Grinder
Any way to take apart cemented pvc drain pipe
if the drain is slow or stopped up, i use a high powered drain opener from ace hardware called "liquid fire" it is different from drano and all that other ****.
Apr 12, 2009 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
How tight should the blade bolt be on a cut off saw
You've answered this yourself. The blade only needs to be nipped up enough to grip. If it slips, it will tighten. Thats why, some machines have a left hand thread, as they always rotate so as to tighten in the event of slippage.
If the blade slips under normal service, suggest you clean both blade and the flanges, and just do it up a little tighter next time.
Mar 04, 2009 | Ace Hardware Ace Chop Saw Cut - Off Blade
Salisbury, Maryland Ace Hardware
You could check thrift stores or as old as it is antique stores.There are stores that sell garage sale items.
Dec 02, 2008 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Bench Grinders Objects
our bench grinder can be used to keep your chisels, knives, gouges and other similar cutting tools sharp, which every woodworker knows is vitally important. Also, bench grinders are handy for sharpening lawn mower blades, drill bits, gardening shears and more. Additionally, a bench grinder can be used for honing and shaping metal objects when modifications are needed. For instance, perhaps you need to modify a door hinge to make it fit in a certain application. No tool is better for this task than a bench grinder.
Aug 27, 2008 | Dewalt 6" 5/8 Hp Heavy Duty Bench Grinder
Take apart
My grinder went from bad to worse and finally stopped grinding (with the motor still buzzing but absolutely no grinding). Knowing I had to do something or throw it away, I pulled the clear plastic bean reservoir upward and separated it from the grinder body. I looked down the hole where beans go down to the grinder and found packed coffee ground blocking the hole. I cleaned the whole thing, put the reservoir back, and my grinder now works like new :-)
Oct 27, 2007 | Braun KMM 30 Electric Burr Grinder
Grinders Logo
97 people viewed this question
Top Grinders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Tom Chichester
bob walter
bob walter
Level 1 Expert
Are you a Grinder Expert? Answer questions, earn points and help others
