Question about Microsoft Video Game Consoles & Games
When testing the connection for xbox live it can't find the IP address.
  • 10,515 Answers
Xbox 360 Connection Tests: IP Address
This test verifies that your Xbox 360™ console has a valid IP (Internet Protocol) address.
If your console does not pass this test:
Confirm that there are no other devices on your network with the same IP address.
If you are using a router or gateway, verify that it is configured to assign IP addresses to network devices (DHCP-enabled).
If you are connected to a router, make sure that your console'sEthernet cable is not connected to the router's LAN port rather thanits WAN port.
If you are connected directly to a modem and your ISP (Internetservice provider) requires PPPoE settings, verify that your PPPoE username and password are correct. If your ISP doesn't require PPPoEsettings, remove the PPPoE user name and password settings.
If you are connecting directly to a modem and have replaced a devicethat was connected to your modem with your Xbox 360 console or anotherdevice, turn the modem off and back on before connecting the newdevice.
If you are using a static IP address from your ISP, verify the address with a your provider.
If your console is connected to an ad-hoc network (in which devicesare connected directly to each other), it will probably not pass thistest. If your IP address is assigned automatically and your ad-hocnetwork does not include a DHCP server, this does not indicate aproblem. The test is properly reporting that a DHCP server could not becontacted. Xbox Customer Support does not support the use of ad-hocnetworking to connect to Xbox Live.
If you're using an ad-hocnetwork without a DHCP server and you can't connect to Xbox Live, checka different diagnostic test for the root of your problem.
This comes from http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/troubleshootliveconnection-testipaddress.htm
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 31, 2009
How do i connect to live?
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live".
applysettings.jpg3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Edit Settings" then "Additional Settings" tab then select "Advanced settings" & put the Physical Address of your PC without the dashes on the "Alternate MAC Address" part and select "Done", when it asks you to Apply Settings choose "Test Xbox Live".
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live". editbasic.jpg3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you'll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Restore to Factory Default" when it asks you to Apply Settings choose "Test Xbox Live".
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to "System" area then "Network Settings" then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose "Test Xbox Live".
If you faced any other kind of troubles with this part failing even after you tried these steps please don't hesitate to leave a comment.
Read more: http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html#ixzz14pRocyB3
Nov 09, 2010 | Microsoft Premium System for Xbox 360
My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
Can't connect with network
if u dont hav e a router that is ur problem. to get ur xbox 360 to connect to vista media center you cannot connect an ethernet cord directly to ur 360, u must have ur computer hooked to a router with one ethernet cord and a whole different ethernet cord connecting to the same router the computers hooked up to. after you do that go to ur vista media center, turn active sharing on, make sure your router is connected to the internet. then go to ur xbox 360 and follow the on screen instruction from the the connect to media center screen.
if your wanting to connect to xbox live and stuff like that, and u enter ur ip address and security information and it tells u that the ip adress u entered is already in use by another device, and that ur xbox 360 needs to be assigned one, do this: simply go to were u put in ur ip address and set it to get the address automaticly (or in other words choose automatic). then go to test connection (ur router should automaticly assign ur xbox 360 an ip address) and ur router should connect to the internet. if it connects to the internet but not xbox live then u have not yet sign up for an xbox live account.
by the way when u make an xbox live account please send me a friend request. my xboxc live account name is: ghdude22
glad i could help!!! :3
Feb 06, 2009 | Microsoft Xbox 360 Controller
Xbox live dont work please help
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
My xbox live doesnt work
If you faced any other kind of troubles with this part failing even after you tried these steps please check me man
Can't connect to Xbox Live
mtu is not working cant hook up xbox live
Nov 25, 2008 | Microsoft Xbox 360 Console
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
IP address
Try this fix:
Apr 13, 2008 | Microsoft Xbox 360 Console
Connecting to xbox live with a speedstream 4100
force the gateway on the xbox configuration... retrieve gate from command prompt of your pc depending on the os.
Jan 28, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Video Game Consoles & Games Logo
161 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
