Question about Midea MPM-08CR-BB4 Portable Air Conditioner
I have a problem with the tab in the water box it is pushed in and may be broken can i repair it
P2 code is displaying
Posted on Jun 10, 2010
P1CODE
Posted on Jun 05, 2010
Y my eseries vsccum can't turn on? thanks
It could be the cord or the switch. The first place to check is making sure the water tank is seated firmly. There is a little tab sticking up from the water tank that pushes on a micro switch in the vacuum so the vacuum can't run without the tank in place. Inspect this area. The little tab on the tank could be broken or the micro switch is not being pushed properly.
Jun 26, 2017 | Vacuums
Why will the motor on my rainbow power on if I hold it up off of the water basin and push the safety switch with a screwdriver but when it's sitting on the water basin it won't power on ?
There is a little tab that sticks up on the water basin, this tab pushes in on the switch allowing the unit to run, I'm guessing the little tab on the tank is broken off.
Feb 06, 2016 | Rainbow Vacuums
How do I repair a non-functioning solution trigger
The trigger has tabs on each side that snap into slots in the handle so that the trigger pivots in the slots. The slots where the trigger pivots may have broken, if so the trigger will not push the valve open and allow the water flow. If the tabs are broken you will need to replace the upper handle. If you supply me with your model number I will determine the proper part for your model.
Dec 14, 2014 | Hoover SteamVac F5914-900 SpinScrub...
1980 corvette with automatic transmission you dont have to push the button down to down shift from 3 to 2. How do you repair this
The return spring inside of the shifter might be weak or broken, or the tab in the shifter gate slot might have worn out or broken. Remove the shifter base and boot and inspect the slot and tab. (the tab rides inside of the slot). An excellent replacement spring can be found at:
Nov 29, 2014 | 1980 Chevrolet Corvette
Rainbow e series will not turn on. Was working fine last time I used it.
There is a switch that is pushed in by a little plastic tab on the water tank when the machine is placed on the water tank. If the tab is broken off or the tank is not installed properly the vacuum will not run.
Sep 29, 2013 | Rainbow E series Canister Wet/Dry Vacuum
Paper tray 2 is stuck -- cant move in or out
the paper lifting rack plastic tabs one of them is broken and the metal that is showing is catching on the guide so the lifting rack is not lowering into place, turn the printer around, remove the door that hides the back of the paper tray, grab the paper size tab and pull it out as far as you can, now get a flash light and either a ruller or a long screw driver and push the lifting rack down into the tray flat and then push the tray out of the printer. once this is done you can examine the broken tab on the lifting rack and call hp for a part number, get a whole baggie of the pieces because they break all the time!!! you can use some fabric medical tape to make a quick and temporary repair. but it will ware out and you will have to do it again. good luck.
Microapex Computer Systems and Printer Repair Center
www.microapex.com
Feb 02, 2011 | HP LaserJet 3600n Printer
How to remove the clasp that holds the glove box front on has broken, so it is only held by one clasp how to remove and replace with a new one. Audi A4 03 reg thanks Gary.
Look here for pics: http://www.thepontiactransampage.com/glovebox.html
  1. Open glove box door.
  3. Put in lock position and remove key.
  5. Insert key.
  6. Turn key to unlatch position and pull lock out.
  7. If the latch needs to be replace un-screw collar.
  8. Reverse to re-install.
Oct 27, 2009 | 2005 Audi A4
Glove box latch broke close. How to open?
Hi, how are you? From what you are describing the latch on the inside sounds like it has broken and is not releasing. You can try to lay on the floor and look up in the bottom of the back of the glove box there are two tabs one on each side. If you push these tabs inward the bottom of the box should come free and help the top to come free. If you cannot see the tabs or can’t get the tabs pushed in, you are going to have to force it open, you can do this with a flat pry bar, wrap the end with a cloth to protect the paint. The good news is that the glove box latch is pretty cheap to replace.
Jul 07, 2009 | 2000 Mazda MPV
Door Switch broken; therefore dryer will not start.
look at your schematic to make sure that you are jumping the right pair of wires. Yes, it should work if you jumper the door switch
Jun 12, 2009 | Whirlpool LER4634J Electric Dryer
Washing machine doesn't agitate
If washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. Note: direct-drive washing machines do not have belts. 1) Check the spin cycle. If this works, the motor is operating and the belt is not broken. If it doesn't, the belt may be loose or broken. If you're fairly handy, tighten or replace the belt, otherwise call an appliance repairperson. 2) Check the lid switch and the tab on the lid that strikes it. If the plastic tab is broken, the washer may halt during certain cycles. Press and release the switch: if it doesn't click each time you do this, it's probably broken. If you're experienced at home repair, you can remove the switch, test it, and replace it if needed; otherwise, call an appliance repair service person. 3) Call a repairperson; there may be a problem with the controls or the agitator solenoid may be broken.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Midea MPM-08CR-BB4 Portable Air Conditioner Logo
291 people viewed this question
Top Midea Heating & Cooling Experts
Steve F
Mike
pawnpower
Are you a Midea Heating and Cooling Expert? Answer questions, earn points and help others
