Question about Microsoft Xbox 360 Console
3 Red Lights
The threew red lights are flashing and won't turn on. It costs 140 to fix and i don't want to spend the money to fix it.
  • 79 Answers
Re: 3 Red Lights
Your console is experiencing a 'general hardware failure' So are you asking for a way to fix it without having to pay 140? You could try the X-Clamp replacement fix but this would mean opening your console and voiding you warranty. Visit, they have many tutorials on the subject. Please rate if useful, thanks!
Posted on Nov 24, 2007
0 characters
3 Points
My ps3 won't turn on and red light keeps blinking,
Read this:
May 15, 2012 | Sony Video Game Consoles
PLAYSTATION3 80 GB has lights flashing:green,yellow,green then flashing red.had a dvd disk that would not eject.i took it apart and removed disk.the dvd had some damage in one will no
Hi there James
it seems to me like you have the yellow light of death, but don't worry this is something that can be fixed.
You have two options here
Option1 you can send the console to SONY for $150, they will send you a refurbished model oh and all data may be lost. The whole process usually takes about 4-6 weeks.
Option 2You can fix the problem at home with a PS3 repair guide worth only $40 a 3rd of the cost of sony, the ps3 will be fixed within the next hour or 2.
Hope this helps
Nov 26, 2011 | Sony PlayStation® 3 (80GB) Console
Everytime i turn my xbox360 on its flashing red like it the red ring of death
1 Red Light
Your system indicates this error when only the bottom right part of the ring is flashing. When you have 1 red light on the Xbox 360, it is usually associated with an error code you see on the screen, such as the Xbox 360 error code E74.
Searching for this error code online or in the Microsoft support site will give you the description and solution. Usually the problem lies on the DVD drive whether it is the wrong firmware or lacks a chip.
It may also be a hard drive error which can be resolved by taking it out and putting it back in or it can be a voltage error which usually occurs if you have added accessories to it. It is best to research the error code so you know exactly what to do.
2 Red Lights
One of the most common is when two red lights are flashing. No need to panic if you see only see the Xbox 360 2 red lights. Its sole meaning is that the console is too hot and needs to cool down. Power down the system and try again in a few minutes or if possible after an hour or two.
After giving the system some rest and playing in a much cooler environment, you should be back to your gaming in better performance. If the problem persists however, you may need to have it serviced to have the cooling issue fixed.
3 Red Lights
If you see three flashing lights, you are experiencing the infamous Xbox three red lights problem that many other gamers are frustrated with. You may also know it as the Red Ring of Death.
At one point 1 out of every 3 Xbox 360 owners experienced this problem. This is the one error that you do not want to get. This highlights that there is a serious Xbox 360 hardware problem.
Your options are to send your console back to Microsoft for repair or to fix it yourself. Be prepared to spend a nice amount of money ($140 or so) if you are sending your system to Microsoft and you no longer have the Xbox 360 warranty.
If you want to try to fix the problem yourself then you can see reviews of guides that we recommend to show you step by step how to perform the repair.
4 Red Lights
If you have to get any flashing lights on your Xbox 360, pray that this is the one. If the entire ring flashes, it is a minor problem that indicates that the AV cable isn't connected properly or in rare instances, the cable is damaged. Make sure everything is properly connected and replace it if It still doesn't work.
Mar 22, 2011 | Video Game Consoles
Three red lights flashing around the power button, Wont let the controller log in.
If you have the 3 red lights this is to do with the GPU and the CPU overheating and you will need to get the system fixed. What you can do is send it in to be repaired and they will fix it for you, although this can take about 4 weeks and cost you $140.
The other way that you can fix it is to do this at home using a good Xbox 360 Repair guide.
I hope this helps and if so can you please rate so it can help others.
Feb 22, 2011 | Microsoft Xbox 360 Console
Wont turn on red light keeps flashing
PS3 won't turn on and keep red light flashing : You need to repair your console. Learn the step-by-step way to fix your PS3 components is best solution for you. I suggest a secret repair kit for you to fix the PS3 errors. This is an all-in-one style guide that help you to fix many cases of PS3 problems. The author is really kind and helpful to his customers. Learn the D.I.Y. way to fix PS3 issues can save you much money. You will receive much more than you spend on it. Because you can help your friends to fix their PS3 too! Please consider to buy it and share what you have learned !
PS3 Red Light and Yellow Light Fixing Guide :
Oct 03, 2010 | Sony Playstation 3 (PS3) Console
When i try to turn on my ps3 it beeps and a yellow like flashes one time and it turns back to the red light. Ive let it cool down for like two days now and still the same problem. What should I do?
Don't waste money to find someone to fix it yet! It may be a minor issue that you can be fixed by yourself.
Remember, you are not the only one to suffer this problem! Actually It is too expensive to send back to Sony repair if your machine is out of warranty!
I had solved the yellow / red lights flashing problems after bought a secret repair kit. This is an all-in-one style that help you to fix many cases of PS3 problems. The author is really kind and helpful to his customers.
Learn the D.I.Y. way to fix PS3 issues can save you much money. You've received much more than you spend on it. Because you can help your friends to fix their PS3 too! Please consider to buy it and share what you have learned !
PS3 Red Light Fixing Kit
Jun 18, 2010 | Sony Playstation 3 (PS3) Console
My xbox 360 turns on and has no video or audio. I just recently self repaired my 3 red lights, however, now when i turn on my 360 there are no flashing lights, red or green, and there is no video or audio....
hey just take a q tip wet it in achol not alot but wipe the in side of the power spot for the adio and vidoe cable spot clean well then wipe out see if that works and if not take off the cover and see if the screws
are loose and if they are tighten them to where there not too tight but snug. and if none of that workd you spend 140 to fix it :(....
Mar 16, 2010 | Microsoft Xbox 360 Console
1 red light flashing
1 red light indicates that there is general hardware related problem with the console, 2 red lights indicate the overheating of the console, 3 red lights indicate the red ring of death and 4 red lights indicate that you need to tighten your AV console wire. If you get any of the problems and your system is under warranty, you can ship your console directly to Microsoft and you will get back your Xbox 360 red ring fixed by the manufacturer, however it might take more than a month and you will also have to bear the additional shipping charges. If your warranty period is over, you will have to pay additional amount of $140, if you choose to send the Xbox 360 to Microsoft for red ring fix. Further you will have to also bear the shipping amount and wait for at least a month for getting your console back. However, you can avoid this and can repair your console your own. There are many good guides available at Internet and you can go through any one of them and can fix Xbox 360 red ring problems your own.
Oct 22, 2008 | Microsoft Xbox 360 Console
3 flashing red lights
it is the ring of death it costs money to repair
Aug 26, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Martin Murray
Are you a Microsoft Video Game Console Expert? Answer questions, earn points and help others
