Question about Nokia Cell Phones
I have an e71X that has can't access the default ringtones
I have an e71X that can't access the default ringtones (factory installed .aac files). I can locate the files on the phone through file manager but when I attempt to change a ringtone under profiles a small pop-up window opens an that says loading but it never finds the files.
I have done a reboot and reformat of the phone as well as restored the phone to several earlier backup point using PC Suite but no luck. Any help would be appreciated.
  • 1 more comment
  • sp115 Jul 31, 2009
    Thanks Mukeshp,
    I can access the default ringtones with file manager, I can even click on them and play them, and as the ringtone is playing I can assign it to a profile. But it only assigns it as the ringtone for an incoming call. This leaves me with the problem of assigning other alets, i.e. message, email, meetings, alarms, etc. And even once it's assigned when I go back into profiles, I still can't find any default tones. It eventually stops searching and provides two options set the ringtone to none or go to mediamall to buy ringtones...
  • sp115 Aug 01, 2009
    Thanks mukeshp,
    I could access them through the file manager which was why it was confusing me. So after posting here, calling AT&T and Nokia, with no luck, I decided to pop out the memory card and restart the phone. Bingo! It located the files through the profiles menu in an instant.
    So then it turns out the problem was either the number of music files (5000 songs) I had on the phone or a card error on the 16G microSD card. A reformat solved it for good, but I'll have to keep an eye on it when I start to reload songs...
    Thanks again.
  • sp115 Jan 27, 2010
    1. Disconnect all devices (headset, charger, USB cable)
    2. Close all open applications
    3. Press power button (briefly), scroll and select ?Offline?, then scroll and select ?Remove Memory?, take out card, select ?OK?
    4. Go to the Idle Screen and type in the one of the following codes:
    a. Soft Reset: *#7780#, then enter 12345 for the password, OK, (restores factory settings, no data is lost)
    b. Hard Reset: *#7370#, then enter 12345 for the password, OK (WARNING! This erases EVERYTHING: installed applications, contacts, messages, images, videos, etc.)
I want to know how to reset master formating without connect computer
Posted on Jan 27, 2010
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 60 Answers
Hi buddy,
If u can see the memory card ringtones then u can see the .aac files too if u still cannot access them then try to access them from file manager
Posted on Jul 31, 2009
How to Create AAC Version in iTunes 12.7?
If you are a Windows user, there is indeed no Create AAC Version any more. But if you try on a Mac computer, you can still make AAC version in iTunes 12.7. You can make it with steps:
1. Open iTunes on your Mac computer.
2. Under the Library, select Songs. Then, tick a song.
3. Click File > Convert > Create AAC Version.
iTunes will convert your music into a new song in m4a format. After the process finished, you'll see there are two different formats of the same song in iTunes. On the display of iTunes, the second one is the AAC version you created; you can click Show in Finder to check it.
If you want to create AAC version to convert music to m4a format, and sync it to your iPhone 8 as ringtone, I'm sorry to tell you that you can't make it any more because there is no Tones icon in iTunes 12.7. You can create AAC version, but you cannot sync ringtones.
If you still want to sync ringtone to iPhone, you can refer to this guide, it will show you the detailed steps pf creating AAC version with pictures. And also introduce you an easy and direct way to transfer music to iPhone 8 as ringtone without creating AAC version:
https://www.imobie.com/support/create-aac-version-in-itunes.htm
Sep 28, 2017 | Cell Phones
How can i access my ringtones to be able to delete ones I don't want ?
Cell phones have default ringtones installed to them by the manufacturers, there's no way of deleting them even if you reset the factory settings but you can delete those that you have personally dowloaded, saved or added on your tones.
I can give you the steps how but you have to let me know what cellphone unit/handset you are using.
Jul 07, 2011 | Cell Phones
Hi , i got a Nokia E71x , and i can not change my clock and date also , when i try to open it , i got "system error" , i bought the phone in USA , and i live in europe , what can i do ,pls help...
Do a master reset:
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone. So please backup all data in phone memory to memory card first.
Enter *#7370# from standby screen, and the standard phone code for nokia phone is 12345
Dec 27, 2010 | Nokia E71x Cell Phone
Cant get ringtones off memory card
firstly the ringtones are of many format such as aac,amr,mp3,mp2 so just check out which is compatibel to ur mobile so that u can view it nd can able to run it....
Aug 30, 2009 | LG Vu CU920 Cellular Phone
Whenever i try to download any songs, ringtones in my mobile the dialog box comes with message- file type is not valid. how to download new songs and ringtones?
For music the Samsung J600 supports the following:-
MP3, AAC, AAC+, eAAC+ & WMA
for Ringtones it supports Polyphonic & MP3 Ringtones
Use these formats and it should work...
May 09, 2009 | Samsung SGH-J600 Cellular Phone
Music file do not open directly from file explorer
to set the ringtone in the file explorer long tap on any file which u want to set as ringtone and menu will appear select set as ringtone and it will be set
for other problems regarding the un installing the software actually the software u installed changed the file associations of these music and video extensions dont worry u can har reset to factory default as under but all data will be lost pls confirm and proceed ur phone will be set as new when u bought it backup ur data first
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
PLS RATE ME FIXYA for help
Mar 31, 2009 | HTC Touch P3452 Smartphone
Cell Phones Logo
261 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
