SOURCE: instruction manual for LG microwave convection oven
You
can download Samsung over the range microwave installation instructions
here. If that's no good, try here.
Otherwise, visit this page, click on click on the left-side arrow "Busque por Codigo del Modelo" in the big purple rectangle, enter your model number in the box, then click "Buscar". They may list an English version manual available for download.
Good luck.
We're happy to help you and we'd appreciate your
thoughtful rating of our answer.
SOURCE: lg microwave LMV1650ST
don't try to fix this yourself, faulty microwaves should be repaired professionaly or replaced.
SOURCE: Jenn Air Microwave Error Code
Hello Hec1152,
I have found the manufacturer contact information for you, but could not find information about the error code. If everything works fine, but the microwave is not heating your food, then the problem is most likely the magnatron or one of it's components, which sadly to say is the most expensive part to replace. Please feel free to contact the manufacturer via phone or live chat to get more details as to what the error code means.
If you would not mind, could you please rate my help. I would greatly appreciate it.
SOURCE: New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes
Failure
Code
Condition
Check/Repair
F1
Open sensor, will
occur below 190F of cavity temperature within 15 minutes after
starting convection, combination or roast cook
Check oven temperature
sensor for continuity. Replace if zero or infinite ohms
F2
Shorted thermal
sensor, will occur if a shorted thermal sensor is detected
continuously over 5 seconds on convection, combination or
roast cooking
Note: It will take a minimum of 5 minutes of convection run
time before F1 or F2 code will be displayed if the thermal
sensor is shorted or open.
F3
Shorted key panel
(touch pad), will occur if a shorted key panel is detected
continuously over 60 seconds
Replace key panel
(touch pad)
F4
Open humidity
sensor, will occur if humidity sensor is detected as being
open continuously over 5 seconds
Replace humidity
sensor
F5
Shorted humidity
shorted continuously over 5 seconds
Replace humidity
sensor
F6
Shorted temperature
probe, will occur if temperature probe is detected as shorted
Replace temperature
probe
ProbEe
Open temperature
probe, will occur if temperature probe is detected open, or
not plugged into the receptacle
If probe is plugged
in and "ProbE" is on display check continuity of the probe
with an ohm meter. If zero or infinite ohms, replace it
SOURCE: Frigidaire GLMV168CS1 Microwave - Sensor Error
If you are handy take it apart. Somewhere inside is a small switch that the door activates. Switch might be broken or a small plastic actuator might be broken. What do you have to lose at this point except time?
