Question about Bose SoundDock Digital Music System for Apple iPod - White
Plug in dock and it makes a noise thru speaker. Getting no power to ipod
CHECK THE SMALL PLUG IN THE BACK , IT SHOULD HAVE THE ROUND PART TOWARDS THE BOTTOM OF THE AMP.
Posted on Aug 10, 2009
My speaker makes a realy loud buzzing noise when I turn the power on
Try turning the volume down before disconnecting.
Jan 06, 2014 | Car Audio & Video
Brookstone iDesign tower speaker either charges and doesn't play thru speaker, or plays and doesn't charge
Don't bother trying to fix it these have a real problem with the connector and board buy yourself a docking station with remote for about $15 on ebay and it will fix you up. Plug into the input Jack and you are back in business. You can buy a Pyle Home PIDOCK1 Universal iPod/iPhone Docking Station cheap on ebay and it has a remote. It will fit nicely on your speaker and do everything you need it to do.
Feb 16, 2013 | Audio Players & Recorders
Don't how to connect iphone to ear speaker
moz-screenshot-12.pngmoz-screenshot-13.pngmoz-screenshot-14.pngmoz-screenshot-15.png honestytessy.jpgHow to Connect an iPod to a Speaker Bar
A speaker bar is a (usually portable) speaker system that includes a dock for an iPod. The unit is usually bar-shaped, with either a rectangular or cylindrical cross-section. Connecting an iPod to a speaker bar is usually as simple as plugging it in. Many speaker bars will also charge the iPod while it is connected. However some do not have an iPod dock, in which case the iPod must be connected by a 3.5mm audio cable.
Instructions
Things You'll Need:
* 3.5mm cable (for some speaker bars)
Turn the iPod on. Look to see if the speaker bar has a dock for the iPod. The dock will fit an iPod perfectly and will generally be located in the center of the speaker bar. There will be a connector that resembles the connector on the docking cable that came with the iPod. Place the iPod on the docking station and turn on the speaker bar. Such is the case with the "2.1 Channel Bar Speaker with Dock for iPod" or the "Yamaha YAS-71BL Front Surround Speaker System"
iPod headphones use a 3.5mm audio cable.
Connect the iPod via the 3.5mm cable. If the speaker bar does not have a docking station it will have a 3.5mm cable connector with a jack like the headphone jack on iPod ear pods. Plug the 3.5mm cable in the iPod headphone jack. Plug the other end in the iPod. Turn on the speaker bar. The procedure is straight forward and Apple specifically designed the headphone jack with third party stereos in mind.
Select a song on the iPod and play it. The speaker bar will play the music from the iPod.
Hope that helped..
have a nice day.
Feb 23, 2011 | Audio Players & Recorders
Only the volume controls work on my Skullcandy Pipe remote control. I can't advance songs or use the shuffle etc
turn on your ipod before putting it into the dock -make sure dock is on aswell then connect it and you will hear a noise like plugging into the computer and then the whole remote will work ! !
Jan 24, 2011 | Skull Candy Pipe Speaker Dock for iPod and...
My ipod docking station charges my ipod but no sound comes thru the speakers
the charge showns that the arm is connecting, but there may be an issue with the docking arm not seeing the ipod. if the ipod is seen, then the led will go blue, or blue flash (if on pause), if this does not happen then it is the arm, check and see if the aux input works, if so then it is just the docking arm, if it does not then could be the main interface board which is a known problem.
contact b and w service.
Oct 10, 2010 | B&W Bowers and Wilkins Zeppelin iPod Music...
No power to ipod when siiting in the sounddock just ticking noise from speakers with or without the ipod sitting in it
You have a wrong type docking board fitted - check you have the right board type. If someone has replaced the docking board with the wrong type then this happens OR there has been a drinks spill in the docking area. About 2 ticks a second. Contact www.invebo.com for a new board or a USB upgrade kit to get your dock to charge the Iphone.
Aug 08, 2010 | Bose SoundDock Digital Music System for...
My iLIVE mod# IT188b will not turn on.... reset button not working either??? this is the second unit I have had(first one did the same thing)but was able to return without reciept...not the case this time!...
This particular unit has issues with bad solder connections on the main audio board which come loose because the woofer speaker vibrates them loose. I've repaired unit myself with a soldering iron.
Dec 02, 2009 | GPX 2.1 Speaker Bar with ipod Dock ...
My bose ipod speakers are making a knocking noise and not charging my ipod
bose ipod speaker been turned of for a few months just plugged it in making a knocking noise is this normal
Jul 11, 2009 | Bose SoundDock® (Black) Docking Station...
Inmotion speeker dock wont charge new ipod touch
This is because you are using different generations.
If the dock was only meant for 1st generation, then itwill only charge 1st generation. It's how they make their money.
Apr 19, 2009 | Altec Lansing inMotion Speaker System for...
Bose Ipod docking station not working!
Make sure the power supply is connected properly. If the power supply is connected upside down or sideways, the system will make a thumping noise, or will not play at all. However, no damage will be caused by connecting this wire incorrectly.
Mar 29, 2009 | Bose SoundDock digital music system...
Bose SoundDock Digital Music System for Apple iPod - White Logo
615 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
