SOURCE: kenmore 70 series model # 96573220
Sounds like the push to start switch has gone bad. Not to expensive to fix, and pretty easy to do as well. You can remove the rear of the console, remove the push to start switch (lift the tab, then turn to unlock) and replace. Be sure to mark your wires so they go back in the right order. Jim
SOURCE: Sears Kenmore Dryer #86681100
I took the top off of the dryer to access the door switch. Took the number off the part and went to Trible's appliance parts and got a replacement. Works fine now.
SOURCE: Buzzer won't go off when dryer is stopped - All else works fine - must leave door open
Fiddled around with the start button. It had gotten stuck in the on position and when I moved it around it freed up. I consider this a temporary fix only and have already ordered a replacement switch.
SOURCE: Dryer keeps running and timer continues to move around dial.
Change your timer. It has a malfunction in it. it's about a 100 dollar fix. Also your start switch may be bad.
