Question about HP Pavilion dv6119us Notebook
Over heats somtimes won't turn comuter very hot
Over heats somtimes won't turn on, comuter very hot shuts off
  • HP Master
  • 2,404 Answers
Make sure that your air vents are cleared, you can do this by using a can of air and blowing them out. There may be alot dust in the slots.
You could also take apart the laptop if you have some technical experience and remove the heatsink thats over the CPU and remove any dust thats built up on the heatsink.
Also make sure you can hear the fan running. If you don't then the fan could be the problem. If the fan is running at all at anytime then you know the fan is fine.
If you go thru these things and the laptop is still overheating then the motherboard is bad and would need to be replaced.
Posted on Jul 31, 2009
  • 555 Answers
Try to buy a external cooling system to prevent the over heat of your laptop. here's the link below to some external cooling system design for laptop.
Laptop External Cooling Pad Design
Thanks
Dream maker spa x-400 won't shut off keeps heating. I have turned it off and let it tottaly cool down the temp max temp is set to 95 and it never shuts off until it gets to 105 and overheats.
I had the same problem last year, I talked to a spa guy and he stated that the temp sensor was probably covered in bio crud. He also stated that the tub should be cleaned with a hot tub flush. After doing that I have not had a problem with the temp settings.
Jan 19, 2013 | Pool & Spa
What do i do?my heating thermostat won't turn off and house is getting hot!
First determine if in fact the thermo is or is not shutting off. There is usually a little indicator as to when it calls for heat .so how do you know it's the thermostat. What type is it electronic or not. Also what type of heat hot water or forced air etc,need to know etc. if house to hot shut the heat off at your service switch,usually wall switch with a red cover.located on the heating unit or a hallway to basement on wall.
Nov 14, 2012 | Dryers
Coleman evcon presidential heater won't kick blower on.
Sounds like the automatic fan control is not working it cuts in on temp rise . It may be dirty on the back of it as you said you had a smell of dust burn
Jun 17, 2017 | Coleman Heating & Cooling
Whirlpool dryer overheats element high heat all heat settings
First check the heating element for short to frame. If it is not shorted remove the filter chute and clear it out. The control thermostat has 4 wires. 2 small wires come from the timer and power up a small heater inside the control thermostat making it shut down faster for perm press and knit cycles. Over time this bimetal inside the control stat won't shut down fast enough or not at all. If it won't shut down then the element will gl;ow reed and the base 250 stat on the heater chamber will shut down. If it fails to do so then the smaller one up top will trip at 300f. If it fails to trip or the filter chute is clogged the fuse skinny white plastic thing next to the control tstat will met and shut down operation.
Here is my HOME MOVIE ROPER DRYER NO HEAT
It shows the various components and how to check.
Jul 31, 2012 | Dryers
I have a 95 monte z34. it is hard to start. the starter heats up and the coil pack sometimes smoke. but once it started it runs great but once you turn it off you cant start it back up for hours. someone...
hi, this sounds like INTERNAL SHORT IN THE STARTER MOTOR( the brushes wire contacting the comutator) meaning the BRUSHES are WORN. smell of burning from starter motor. (somtimes the starter motor stays engaged to the flywheel and the starter motor go's supersonic and distroyes itself). but get other advice first. in case i am wrong. DO NOT RELY ON MY ADVICE. gerry
Sep 11, 2010 | 1995 Chevrolet Monte Carlo
Amplifier turns on and works till it gets hot then
This sounds like a problemn the power supply area, possibly near the filter caps. I would look for a cold soldering joint at or near the filter caps as a start.
The problem is a mechanical connection problem since vibration "fixes it".
Capacitors are heavy and often due to handling the soldering is broken at the terminals. As unit heats, these start to oxidize and break contact, but vibration temporarily restores them.
Dec 17, 2009 | Peavey Music
My su g90 shuts off when i turn it up loud what do
Amplifiers get hot. The more you crank the volume up (or use extended for extended periods), the more current is required. When it gets hot, there is a fan motor (on the back), that should turn on. I believe your fan motor (brush) is worn out and therefore non-functional. Under this condition when the system overheats, it automatically changes mode to protect circuits.
Also note: if it works when you initially turn it on (cold) for a few minutes it should work fine...until it starts getting hot inside the case.
Oct 20, 2009 | Technics Audio Players & Recorders
My 2001 case 586e forklift will just quit running
check the fuseable links arround the starter
somtimes they seperate when they over heat and the ruber contracts when they cool down
if they are cooked they will pull apart fairly easily when hot
Sep 16, 2009 | Milwaukee Tool Case Heat Gun
My TV turns off by itself. How do I correct this? my tv turns of after 10-20 minutes and blinks 3 times red after being off. How can I fix this.
this is somtimes do to an old lamp causing the tv to over heat and shut down. wich would also explane the error code (blinkinglights after shut down)
Jan 22, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
HP Pavilion dv6119us Notebook Logo
106 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
