Question about Refrigerators
Water filter froze solid - Refrigerators
  • 560 Answers
Your refrigerator compartment temprature is below 32 degrees and freezing your water in the filter. Adjust the thermostat setting to a higher temprature setting using a thermometer in the referigerator as a refrence. 34-37 degrees is a good temprature range to keep food fresh.
Posted on Jul 31, 2009
Model KFIS25XVMS9. Why doesn't it make ice?
sounds like the ice maker is the problem not the inlet .
Oct 15, 2015 | KitchenAid Refrigerators
WATER DISPENSER ON GALAXY SIDE BY SIDE REFRIGERATOR DOESN'T WORK
Sounds like if your ice maker is still working, you're having an issue with your filter maybe freezing. Check to make sure your water filter isn't froze. What you're talking about with the overflow is a coincidence, but unless the internal wiring for the unit inside of the dispenser got damaged, i doubt thats the reason why. It's either a frozen filter or bad water valve. Try dethawing the filter or taking it out and seeing how much pressure there is built up in it. There's also a water reservoir in the back of this unit that may be froze too.
Nov 27, 2013 | GALAXY Microsystems 25.4 cu. ft....
Water Filter Frozen
Air blowing directly on things like a water bottle has frozen it solid ( in the REFRIGERATOR SIDE! -- Block airflow BUT... I think the problem is YOU NEED TO CLEAN ( blow out with air!...the ONLY WAY) YOUR CONDENSOR COILS ( in the back, outside...behind the cardboard cover nowadays) Your fan has to run too long ( because refrigeration is the "removal of heat"...this is what those coils do but they are insulated with dust!)...too long blowing to achieve the same temp result = Frozen Stuff
Sep 24, 2017 | Frigidaire Refrigerators
What's a mechanical filtration?
Mechanical filtration is the straining of solid particles from the aquarium water. Most common mechanical filter media do not remove microscopic bacteria and algae from the water. Neither will mechanical filtration remove any solids trapped by gravel, plants, or decorations. When using this method you'll need to use another method in addition in order to get rid of the solid wastes in your aquarium.
Aug 09, 2012 | Fish
Water dispenser just stopped working. Ice dispenser still works and the refrigerator has a new filter
two possibilities
1) the water valve is defective it has one inlet from the house plumbing,two outlets, one for i/m one for water dispenser
2) the reservior that chills the water is frozen, it is located behind the lower crisper drawers in the ref. to see if its frozen remove crispers and shelves and tap on it , if hollow sounding it's not froze if solid sounding its froze. to thaw it turn off unit for at least a hour
Jul 21, 2011 | Kenmore Side by Side Refrigerator
New unit never used found the water filter cracked
THE FILTER HOUSING MAY HAVE FROZE AND BROKE. MAY HAVE FROZE ON TIME IN SHIPPING. CALL ELECTROLUX THEY WILL SEND YOU THE PART AND A TECHNICIAN TO FIX IT. SO IT COULD BE REPAIRED IN ONE TRIP.
Apr 24, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
No water to the ice maker
filter cracked because it froze . changing the filter is not enough change the housing . as the lines are frozen and wll brake . mm
Apr 18, 2010 | Frigidaire FRS26H5AS Side by Side...
Fridge is freezing in weird spots, the water filter froze, it was time to replace it, so I did and the new one froze as well. Also, are the water filters a one shot deal? I took it out to see if it was...
Make sure the evaporator fan in the freezer is running when the compressor runs and make sure the vent from the freezer to the fridge is open allowing for the air to circulate. There is also a vent at the bottom to allow the air to return to the freezer. Make sure it's open.
You may need to let the filter dry out so it will return to it's original size and shape so you can get it back in.
Jan 20, 2010 | Refrigerators
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
The unit behind the filter is frozen solid.
turn it off thaw out clean evaporator clean filter the grinding is the blower wheel hitting the froze solid. hope the blower wheel is not wrecked. use 409 to clean. Tom
Jun 17, 2009 | LG Art Cool LA121CNP wall/window Air...
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
