Need how to access bios setup utility -Panasonic CF-270 Notebook.
I have Panasonic CF-270 Business Partner Notebook. What is the keyboard sequence to get into bios setup utility?
This model does not use a typical F-key. It works thru a program (setup270.com) that should be available on the hard drive, and it is limited... There is no HD configuration available for this machine and it is configured for a limited number of drives. Use of a Dynamic Drive Overlay (DDO) is necessary to install a drive larger than OEM. I have had success up to 1033mb on a sister machine, Tandy 2810hd.
Posted on May 24, 2013
  • 555 Answers
To access your BIOS Setup please restart your laptop then during the first boot process kindly press either the following:
1. F1
2. F2
3. F8
4. F12
5. F10
6. Del
7. Esc
Cause the bios setup is design in different manufacturer of laptop so the best thing to do is read the information during the first boot of your laptop it is always display the keyboard sequence to access the bios setup.
Thanks
Posted on Jul 31, 2009
How do I reset the bios Password on a Panasonic Cf-51
This method may help;
1) Locate and remove the RTC battery
2) locate and remove the main battery and unplug power supply.
3) depress the power button for 30-60 seconds.
you do not have to solder anything to the board if there are posts ic 61,63 on MAIN PCB then just put a jumper across them while you power up. if its just 2 SMD pads just use a needle probe to arc the connection.
Oct 10, 2016 | Panasonic Toughbook CF-51 Notebook
How do I get into the BIOS?
- Start / Restart
- At the Panasonic velcome screen, press the [F2] to enter the BIOS Set Up Utility
http://datasourcemobility.com/photos/CF-74_Care_and_Maintenance.pdf
Apr 05, 2015 | Panasonic Toughbook CF-74 (CF-74HCDAZBM)...
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    Setup utility
    To get into the built-in setup utility on a Panasonic
    CF29 Toughbook, please turn on the unit and immediately
    press the "F2" function key repeatedly.
    As long as your unit has a working keyboard, the setup utility
    should open. If no password is required, then you can enter
    the setup utility and make changes.
    Please be careful about making changes. If you make a
    change and then want to go back, you can either exit and
    discard changes, or you can set factory defaults in the last
    (right side) selection and then exot and save changes.
    Good Luck to you.
    Regards from Richard in Montreal.
    Authorized Panasonic Canada Toughbook Dealer since 1989
    Aug 02, 2013 | Panasonic Toughbook CF-29 Notebook
    The Phoenix Bios setup utility is password protected now. I had to replace hard drive but won't let me reinstall cause says it needs a password. Is there a way around that?
    No0 theres not... your going have turn to your manufacture for help to reset the passsword or te person that put the password on! Goodluck
    Dec 03, 2010 | Panasonic Toughbook CF-51 Notebook
    What is the boot up sequence please
    You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
    Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
    Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
    Hope this helps!
    Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
    Lose TravelMate 270 Series Notebook..bios paswoed
    In order to remove password an (educational) solution is to open your laptop back with a screwdriver carefully and remove the bios battery (its a small silver colored round one) and put it back after 5-10 minutes. Then you can close the laptop back and access the bios setup utiliy by pressing the f2 or the f number displayed on startup and replace or deactivate the password. Another solution is to use a backdoor password according to the manufacturer and deactivate the password (search googlefor it) or use a small software utility like !BIOS if i remember correctly to retrieve the password but it may take some time. I hope that helped!
    Feb 08, 2010 | Acer PK13BY27110 TravelMate 270 Series...
    How do i change boot sequence
    When the BIOS starts and the company logo comes on, there is a bunch of words written at the bottom of the screen.
    See for one which is something like "change boot order". Press that corresponding button on the keyboard. Now follow the things on the screen and explore.
    You cannot use the mouse in this 'DOS'sy looking screen. Use the arrow keys on the keyboard to navigate.
    Nov 27, 2008 | Panasonic Toughbook CF-51 Notebook
    Computers & Internet Logo
    766 people viewed this question
    David Payne
    David Payne
