Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
The water in the door does not dispense cold water
The water comes out sort of cool, not cold. what's up?
  • LG Master
  • 2,651 Answers
Holding tank is in refig compartment so water is going to be as cold as refrig 38-40
Posted on Feb 25, 2008
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
Water is no longer coming out of the water dispenser. The fridge is plumbed in and water is getting to the water filter and the ice maker but not coming out of the dispenser.
small_4_1.jpg For a detailed Refrigerator illustration, click below.
redarrow.gif Side by Side
redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
Warning!To avoid personal injury or even death, always disconnect yourappliance from its power source--that is, unplug it or break theconnection at the circuit breaker or fuse box--before you do anytroubleshooting or repair work on your appliance. Also, because somecomponents may have sharp edges, use caution while working on yourappliance.
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Jul 16, 2008 | Samsung Refrigerators
At back of unit I disconnected line and get water and I know that the switch works but no water comes out front?
When you push in the water dispenser do you hear two clicks? The first click is the switch in the front. The second click is the solenoid in the back. The solenoid has to open to let water through. If you don't hear that second click then it is most likely the solenoid.
If you remove the grill below the fridge doors you will find a plastic line and a coupling. disconnect the coupling. Push the dispenser arm in and see if water comes out. If it does then you have a frozen water line in the freezer door. Most likely it is frozen right below the ice cube dispenser door as it sometimes leaks out cold air if it does not shut properly. You can use a heat gun or hair dryer to thaw the line. Be careful not to melt any of the components.
If you do not get water out of the line at the coupling then it may be frozen in the fridge cooling coil. This is rare and usually only happens if you run your fridge on a very cold setting.
Jan 24, 2011 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Cool water switch seems to be faulty, no water but ice maker seems to be working how do I get access to switch?
Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. . GE makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173.
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad
Jan 12, 2011 | Refrigerators
Water is leaking under the frezzer into the frig and it ices uo in the frig to right in the middel where the cool air comes from the frezzer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
Oct 10, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
The water in the door that comes out by the ice is not cool at all. tap water is colder
Since the cooling tank is located in the refrigerator area behind the crisper drawers, the only explanation for less than col water coming from the water dispenser is that your fresh water line is connected to the hot water spigot instead of the cold one.
Jul 31, 2010 | Kenmore 57029 Side by Side Refrigerator
Not getting cool water from dispenser in door
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
Mar 28, 2009 | Samsung RS2534 Side by Side Refrigerator
The water in the in-door dispenser is coming out hot
If this freezer is like most, the water going to the dispenser is looped around many times in the refrigerator section near the back. Make sure that this is still true. It must have a lot of water cable in the refrigerator section so that the water has time to cool down before it goes out the dispensor. If for some reason the water tube is touching either the compressor motor or another hot part of the external refrigerator it could cause it to be to hot to cool down in time during its travel through the refrigerator as well as it will start to warm up the refrigerator section as well.
Also, I am sure you have tested, but make sure that you are plugged into the cold water supply and not the hot water supply. Check the water at the connector and see what the temp is at that point before it enters the refrigerator.
My guess is that the coil of water tubing that is usually in the back of the refrigerator section has been either lessend in length or the water entering the refrigerator is too hot to be cooled down in time before it reaches the dispenser.
Feb 03, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Water/ice maker not working and freezer/frig not cooling evenly(top warm/bottom cool)
the relay valve that controls the water is stuck.
likely hard water deposits,
Feb 03, 2008 | Jenn-Air JCD2295HES Side by Side...
Warm Water out of water dispenser
Usually the coolness comes from a large coil of plastic tubing in the refer compartment that stores the water. Check that the refer compartment is cool enough. Also see if running a large glass or two becomes cool again and stays cool for a while. Usually the very first 1/2 glass may be warm until the "cool" water that is stored in the coil of tubing finally makes its way to the dispensor.
Aug 25, 2006 | LG LRFD21855 Stainless Steel French Door...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
326 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
