Question about Gateway GT5220 PC Desktop
Screen has a blue tint - no red
Have replaced the monitor, checked the connections, even unplugged them and then plugged them back in. At different times it has worked with color (turning off and then back on worked for a while, a game that changes the color settings sometimes kick starts the color back to working)
  • 2,404 Answers
Sounds to me either your video card is bad if your computer came with one or if your video card is integrated into the computer then the motherboard is bad.
Basically if you have a video card, it will plug into either a PCI or AGP slot and alot of times they overheat or the fans fail on them. If thats the case you would replace the video card. If you have integrated video on your motheroard meaning you don't have a card and you plug the monitor into the motherboard video connector then the motherboard is bad and would need to be replaced.
Posted on Jul 31, 2009
I unplugged my Acer al1914 monitor from my computer and plugged a different acer al1914 in my computer and now when I transfer the screen from notebook to monitor it has a blue tint on the entire screen. I...
Check the color settings in the on-screen menu. You can choose between "Warm", "Cool" and "User". Maybe you used the "Warm" setting before and somehow it got changed to "Cool".
If this is not the case, you can try the "User" mode and reduce the intensity of the blue channel.
If even black areas show a blue tint, maybe running an auto configuration from the menu helps.
As a last resort, use the "Reset" menu item which resets all settings to factory defaults.
Mar 30, 2010 | Acer AL1914 19" LCD Monitor
I just bought a New E-machine about a week ago and plugged it up to my TV monitor, now my screen has some sort of green bluish tint to it . When i unplug the computer and hook it up to the DVD or...
You didn't indicate what type of connection you have between the TV and the PC. The basic color scheme is red-blue-green, so your tint sounds like it's missing the red. It could be a cable problem, can you try replacing it/them. Or it could be a problem with the computer. If you don't want to return it you could try a different video card. I'm assuming you are using the motherboard video drivers.
Jan 17, 2010 | E-Machines eMachines T3830 PC Desktop
Green tint display
The monitor is faulty, not enough red. you can make changes in your display advance settings to try and reduce the yellow and blue to make the screen look a bit better. you might want to try a differant vga cable or check the pins in the plug that nun are bent
Aug 18, 2009 | Star Logic 17" LCD Monitor
Blue hue on screen
Try a different known working monitor on the vga port of your laptop. If the replacement monitor works then you definitely know its a problem with your original monitor. If the replacement monitor shows the same blue hue then you know the vga port is bad on the laptop which would mean replacing the motherboard since its connected to the laptop.
May 30, 2009 | Acer AL2016W 20" LCD Monitor
Monitor screen changes from regular color to a green tinted screen?
Connect a different monitor to your computer, if it still displays the same fault the the problem is the video card and you need a replacement.
May 27, 2009 | Dell Computers & Internet
Computer has red tint!HELP!!!!!!!!!!
If it is under warranty, take it back. Elsewise caveat emptor.
Mar 06, 2009 | Gateway FPD1975W 19" LCD Monitor
Blue tint on computer display monitor
Try
1. Unplugging the video cord from the back of the computer (and screen if it comes off) and plugging it back in. Sometimes it can become loose and cause a screen to have a abnormal color contrast
2. Updating the drivers to your card
3. Trying a different monitor on the computer. Mind you, if you plug in a differant monitor and the color stays the same. Check the videocards pins on the back of the card. I dont know if you gave all the info on how it became like this, so maybe it got undone and plugged back in forcably and one of them got bent? I
Also if the pigment goes away. Plug the normal one back in and if its gone, great!, if its back. Try the OSD settings on that monitor. Still no luck. The monitor is junk.
Hope that helps
Nov 30, 2008 | ViewSonic Computers & Internet
Monitor tint is blue
u just take it to a comuter place and pay 5 to 8 dollars to bye a new cord because even though u put the cord back the way u think it was the inside of the cord is damged and try to keep your dogs away next time but im sure your already doing that?
Nov 09, 2008 | Acer X163WB Monitor
Monitor is blue-evrything has a blue tint-i can see colors,they just have a ble tint
I've found that strange color tints are usually the result of a loose cable connection, either at the computer end of the monitor end.
Try unplugging both ends, and then replugging both nice and securely (might even try reversing the direction of the cable, if it is a simple VGA-VGA cable).
Feb 27, 2008 | Computers & Internet
Blueish screen
Follow these steps to solve the problem... Make sure that the moniter power button is off. Unplug monitor from mains ( the auto exit button should flash red after about five seconds and you hear a popping sound.) plug monitor back in mains. hold down + and - on the monitor now hold down power button on monitor let go of power when power button when the green led lights up let go of + and - buttons wait a few seconds and press menu, a hidden menu will appear in the top right use the + and - buttons to move the highlighted option over the auto colour option in the menu push the menu button.
Jun 08, 2007 | iiyama ProLite E434S 17" LCD Monitor
Gateway GT5220 PC Desktop Logo
256 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
