Question about Connex CX-4300HP CB Radio
Can"t transmit - Connex CX-4300HP CB Radio
  • 141 Answers
Check SWR on Antenna
Check Mic
Make sure its set to AM
Set it to "D" Band
Posted on Jan 30, 2010
  • 631 Answers
I believe that if the radio is not tuned to the antennae it can take out the transmit crystals and the radio will be inoperative. You will have to take it to a shop that works on CB Radios to have it checked.
Posted on Jul 31, 2009
Yaesu 3100 transmit problems
There are several reasons you may not be able to transmit with the FTM-3100R:
1) Your antenna is not matched to the frequency of use and presents a high SWR. The 3100 protects itself from high SWR by refusing to transmit
2) You have somehow enabled the busy-channel-lockout feature in the setup menu, and you are operating with an open squelch
3) Your DC power supply voltage is too low to support transmit current
4) You are transmitting with too low a power setting and the receiver cannot hear you
5) You are attempting to transmit to a repeater that uses a CTCSS squelch tone, and you do not have the proper squelch tone configured
Both of the LEDs to the left of the display should turn red to indicate you are transmitting. If both LEDs turn red, your problem is likely either #4 or #5.
May 21, 2017 | Yaesu Radio Communications
I have a nokia lumia 625 and it does not pick up 5ghz wifi, any clues. It picks up 2.4ghz ok.
You can only get higher than 2.4ghz from your router if you are using a ''wireless N'' router and your phone must be wireless N capable. The fact that you are asking this question, probably means your phone is capable of ''N'' reception, but your router is not ''N'' compliant. You are probably using a ''B'' and/or ''G'' type router, which would definitely only transmit at 2.4ghz. // By the way, even ''N'' can be transmitted at 2.4ghz. The ''ghz'' isn't as important as whether or not the router can transmit ''N'' wifi frequency. You can tell by the download speed. ''B'' & ''G'' won't transmit faster than 54gb per second. The ''N'' speed is upwards of 100gb per second. All three (''A'', ''B'' & ''N'') can be transmitted at 2.4ghz if that is the router's rating. The ghz is not really about ''speed''. It is about the fact that many wireless devices (such as landline telephones) transmit at 2.4ghz, which can interfere with the router's 2.4ghz signal. So, using a router that transmits at 5ghz won't have interference issues with other 2.4ghz wireless equipment. // In short, what matters is that your wireless ROUTER transmits with the ''N'' version of wifi.
Jan 01, 2015 | Nokia Cell Phones
Kenwood tm-281a transmitting but no one can hear me.
How is your antenna? Do you have another 2 M radio? Try feeding a dummy load and listening on another radio nearby. Look at the display when you transmit. Does it show the right frequency? If you have the offset wrong and it is taking you outside the band, it will likely not transmit. Do you have a power meter? Does the rig's current drain go up when you try to transmit? (Does the power supply keep the voltage up when you try to transmit?) Supply voltage dropping will cause the rig to NOT actually transmit.
Nov 14, 2014 | Radio Communications
My hr2600 shows error 3 when it is keyed up and does not transmit
0 = Transmitter Timeout timer has timed-out
1 = Transmit Frequency is lower than TX Lockout Lower Limit
2 = Transmit Frequency is greater than TX Lockout Higher Limit
3 = Phase-locked-loop (PLL) won't lock at this transmit frequency
4 = PLL is intermittently coming out of lock during transmit
*If your radio displays error 3 or 4, don't keep trying to transmit on this frequency. The cause of the problem could be low power supply voltage to the radio or the radio's VCO loop needs adjustment. Refer to a qualified technician for service. Contact the installer of the chip first. If, however, you installed the chip yourself, contact a qualified technician for service.
Sep 24, 2013 | Magnum DeltaForce CB Radio
Ftl2011 nao transmite
More information is needed to help you; On which frequency are you trying to transmit? The radio has its band limits set by regulations of different countries. If you're trying to transmit on a frequency that's outside the limits of what the radio is setup for, it won't transmit.
Sep 08, 2013 | Vertex Radio Communications
Display says OFF
You are on a portion of the 2 meter band that the radio does not allow you to transmit on. You need to get within the legal band portion and transmit there. The IC-V8000 only transmits between 144.000mHz and 148.000mHz. You likely have the radio outside of that range.
May 17, 2012 | Icom IC-V8000
I have a motrola cp110 that will recieve transmissions, but will not itself transmit. When i press and hold the transmit button, it lights to show that it should be transmitting, but does not transmit any...
Check your programming, and also check your battery. It will take more energy to transmit than to receive. Sometimes this is simply an indication of a bad battery. If this does not solve the problem, you might want to have your radio serviced. (Current flat rate repair is around $85 at dealers where this model is repaired.)
best regards.
May 22, 2011 | Radio Communications
I'm using d-link dwl-3200 ap ( three) Received Frame FCS Error Counts indicate a problem? ___________________________________________ WLAN 802.11G Traffic Statistics Throughput Transmit...
Transmitted Error Count 4734440
Ack Rcv failure Count 15269951
  • As per the above there are error on Transmitting the packet and also for receiving the acknowledge packet.
  • Please check whether any disturbance in the link
  • Each PPP packet has a checksum attached to ensure that the data being received is the data being sent. If the FCS of an incoming packet is incorrect, the packet is dropped and the HDLC FCS count is increased.
  • Another reason for seeing too many FCS errors may be that the remote end has stopped talking PPP.
Feb 27, 2011 | D-Link AirPremier DWL-3200AP 802.11g/b...
I have an isuzu pick up 1983 diesel 5 speeds , the transmition its failing, one mechanic tell me that the transmition mesh are mabye spoiled or broken, i dont move to much my isuzu to dont damage more...
If its a bad syncyro ring, then it could be repaired without a big parts expense, just labor
It might be cheaper to find a used tranmission and swap it out
Oct 14, 2010 | 1983 Isuzu Pickup
Hisses/squeals when transmitting
Check the input voltage into the radio while in transmit. The voltage maybe dropping as you go into transmit which causes it to drop into receive. That in turn allows the voltage to come back up. With your finger still on the PTT it tries to transmit again, etc. This could cause a feedback squeal and other symptoms.
May 30, 2009 | Uniden PRO538W (40 Channels) 2-Way Radio
Connex CX-4300HP CB Radio Logo
131 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Mitch Davis
Mitch Davis
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
