My trio tablet shows a full green battery charge on the screen,and then turns off, wont turn on
You Power Cord must be bad. If you cannot get on the laptop by using just the power cord, then the power cord is bad and needs to be replaced. Also it sounds like you've been operating off your battery since the power cord is bad, but now the battery is dead because the bad power cord was not charging it.
Get a new AC Adapter and Power Cord. Or it could be that the pin where you plug the power cord into the table is damaged or broken.
SOURCE: sony tablet wont come on
A model name and number would have been helpful. However, it is likely that the tablet needs resetting. Check out this website from Sony for some tips on this.
SOURCE: my mid tablet will not charge
your charger probably died. go out and by a new one and see if that fixes your issue.
SOURCE: my tablet wont charge or turn on please help
Check its charger. If the charger is faulty, it won't charge the battery. If it is found OK, replace the battery. It is bad.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: My table wont turn on.
Try using reset. You will probably need something small and skinny to push reset in the small hole on the tablet
