Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Jenn-air svd48600 display dimmimg and will not heat.
I noticed that the display was dimming and then a week or two later it stopped heating. Are they related? I hear a clicking like it's turning on but then soon after hear another one like it's turning off. Could they both be run through the same relay or control module?
The problem lies with the circuit boards. However, I'm not sure it's with the control/relay board or the display board. More likely the former one, but again, I'm not sure.
Posted on Jul 31, 2009
  • CalgarySimon Jun 14, 2014
    It's most likely is a problem on the display board. Fixed my Jenn-Air Convection Oven (Model - JJW9530BCB) by changing that circuit board for about $200. But actually can be fixed with a few bucks - It's the broken C3 capacitor on display board, replace it with same 68uF 35V or bit higher uF & higher voltage capacitor. Yes, a 50 cents capacitor is usually all the problem for a $$$$ oven to stop working. & I bet many people just spend extra $$$$ to get a new oven.
Jenn Air W30400 wall oven does not heat.
Turn off the power to the oven.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
Dim displlay on oven controls. Dim all the time, as oven heats to desired temperature, controls are not legible.
SEE INFO AT THIS LINK: http://www.fixya.com/support/t4256191-ww304430p_lights_control_pannel_very_dim.
Or use "Dim Display as search term.
($5.00 +/- DIY fix if it works, sure did for me.)
May 24, 2010 | Jenn-Air JJW8230D Electric Double Oven
Oven digital lighted display is dim
You need to replace the C3 capacitor on the control board
http://fixitnow.com/wp/2009/01/28/cheap-fix-for-a-dim-display-on-an-oven-control-panel/
You can replace only the C3 - it is 68uF / 35V and you can go to Radio Shack and get their part # 272-1028 - 100uF/35V one. It takes all but 10 minutes to re-solder the new one in place
May 31, 2009 | Jenn-Air JJW8530C Expressions Collection...
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
Nov 27, 2008 | Jenn-Air JJW8530C Expressions Collection...
No digital display oven works
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 21, 2008 | Jenn-Air JJW8527C Expressions Collection...
No display, No beeps, No heat
I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
Jul 15, 2008 | Jenn-Air JJW8530C Expressions Collection...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
444 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
