Question about Frigidaire FRT17G4B Top Freezer Refrigerator
How do i get clean ice cubes from frigidare?
I have a Frigidaire fridge by Electrolux and it makes ice cubes on its own. The problem is that the ice cubes taste like **** and stink too. How do i get nice clean ice cubes?
    President:
  • 704 Answers
In order to get as clean an ice cube as possible, it all depends on the quality of the water that goes into the ice maker. If you have a water softener, your cubes will always be a bit cloudy, since the added salt slows down the freezing slightly and thus the cubes get cloudy.
That said, there are a few things you can do to improve your water. Adding a whole house water filter with a sediment charcoal filter, will remove the impurities and help to improve the overall taste. Then add an inline charcoal filter on the water line into the fridge. That will filter your water a bit more and help further improve the clarity and taste of the cubes.
Beyond that, you might want to look into a reverse osmosis system to really get the best possible tasting water you can.
The old adage of "garbage in, garbage out" is a good analagy for water quality issues, so you need to figure out what's in your water in order to take the steps to treat your water for the best possible results.
I recall that Sears offers free water testing (to help sell water softeners) so that's an option, as well as getting a home water test you can perform yourself.
Hope that helps you with your situation. Best regards!
Posted on Jul 31, 2009
  • 10,865 Answers
The quality of your cubes is determined by the water going into the fridge, and the cleanliness of the ice cube maker and the tubing that carries the water into the ice cube maker.
If your fridge has a built in water filter, the newer ones often do, you will have to replace the filter. If not, you will have to either clean the tubing and the unit or replace them.
How is the quality of the water coming out of your faucets. If it tastes like **** then you will have to get a water quality company to come in and check it out. They come for free and are in the yellow pages. They will want to sell you a water filter or possibly even a system to clean your water.
Get back if I can assist you further.
I have a brand new frigidare refrig and the cubed ice from the door comes out with a film on it and sinks to the bottom of the glass..how can i stop this?
It might be a food safe lubricant that needs to be cleaned out of the system yes clean the trays and anything else in that area also look in the manual under trouble shooting, if you have had the fridge piped in so the ice maker works auto there is a possibility of flux in the pipework but if you say the water is fine then a clean should cure any problem.
Sep 19, 2014 | Frigidaire FRS3R5EMB Side by Side...
Water and Ice Cube Dispenser not working
Water supply problem most likely. Check inlet solenoid and filter
May 15, 2012 | Electrolux Refrigerators
Power to the ice maker/water dispenser seemed to have shut off. Ice maker is still making ice, but the dispenser is not working. Is there a fuse or something?
frigidare 36' side by side. makes ice, nothing comes out of the door dispenser, auger truns. prior to this it would only give crushed ice even if set on cubes
Dec 06, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have model# FRS26R4AW5. The ice dispenser wil
I have a few ideas for things to try. On the bottom of the ice cube holder I believe there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. Make sure this metal rod is free to rotate. Sometimes it gets stuck in one position. The position of the plastic piece inside the indent in the rear of the freezer is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced. I hope this helps you out.
Jan 09, 2010 | Electrolux Refrigerators
Frigidare stuck on crushed ice.
I have a few ideas for you to try. On the bottom of the ice cube holder there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. The position of this plastic piece is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced.
Jul 06, 2009 | Frigidaire FRS26R4A Side by Side...
My ice maker crushes all of my ice as it comes out the door. Help me - I'm strictly a cube kind of girl!! Cindy ( I've already tried to push the "crush" button and then the "cube" button again. The...
unplug the fridge 2-3 minutes and see if it resets the computor to make the ice control work normally again. You can also open up and get the cubes out cheaper than having it repaired. Sorry about that!
May 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Frigidare ice maker making slabs of ice, not cubes
Today, I removed ice maker and auger motor. Found out this morning that water was running down the back of frig. inside, everything in freezer was frozen together. Found this out after removing all food from freezer. When i looked into the ice maker where water enters, that was frozen solid. After thawing and checking everthing. I put it back together in freezer. It is nine oclock now, and I do have cubes. I really can't tell you what I did, except thaw it all out. It's been running for four hours now and it seems to be all right.
Nov 16, 2008 | Frigidaire Dryers
The ice cubes come with white powder
Hey there....
The white powder in your ice cubes is the water line to the dispencer,The water in the pipe forms a white layer after some time,almost like the kettle around the aliment,you just have to clean the pipe out,i normaly use some hot water with a bit of vinigar,just make sure you flush the system after wards and there you go....
Hope you get it right...
Wouter.
Sep 10, 2008 | Frigidaire FRS26R4A Side by Side...
Ice Cube maker stops making cubes as they are being made ....
Ice makers use a small heating element to release the ice from the mold tray..sounds like that isn't working and everything else is. Check to make sure all electrical connectors coming from the ice maker are properly seated into their mating connectors. If that doesn't solve your problem, you may be better serevd by just replacing the entire icemaker assembly.. Hope that helps...
Jul 25, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
339 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
