The contrast on the upper LCD screen is too dark. How do I increase the brightness so I can read the dictator's ID and job type? The lower LCD screen brightness is perfect!
  • 1 more comment
  • wdwnnad Jul 31, 2009
    This is not a copier machine. This is a Lanier VoiceWriter EX teletranscriber, which is a glorified telephone from which I receive dictation to transcribe. There was no specific category for transcription equipment, so I chose Office Machines, and was shunted to "Copiers." Sorry for the confusion!
    I am using a Lanier VoiceWrite EX transcriber, connected to a phone line in order to transcribe medical reports. The top LCD panel back lighting is so dim that it is hard to read the ID of the dictator and the job type. Is there a way to increase the brightness of this panel? The lower LCD panel brightness is perfect. I originally selected "Office Equipment" because there was no other category from which to choose, and your system shunted me into "Copiers," which of course is not correct.
    It was very helpful. The problem is this is third-hand equipment my primary contractor gets from others when they upgrade, and it's probably close to obsolescence. I appreciate your help! Thank you so much.
    President:
  • 2,185 Answers
Surely your problem is in your LCD's backlight because the contrast is supposed to work for the entire LCD screen.
But you can still try to isolate problem by going to the LCD settings and change the refresh rate. Bring it up higher. If it doesn't fix the problem, then you might want to change your LCD backlight.
Here is a fix:
http://inventgeek.com/Projects/BacklightFix/Overview.aspx
but you should be highly experienced with this stuff to do this, otherwise, you can bring it to an authorized service center. If its still under warranty, the better.
Posted on Jul 31, 2009
    Genius:
  • 1,689 Answers
If the LCD does not have a balanced contrast, the crystals in the panel may be damaged does adjusting the contrast may be of no use.
what is the brand and model of your printer?
How can I increase brightness?
Download and read the manual
http://www.retrevo.com/support/Envision-EN7100e-Monitors-manual/id/511ci960/t/2/
Jul 18, 2014 | Envision EN-7100e 17" Flat Panel LCD...
Dark pictures
Increase your brightness or decrease darkness setting under display in your menu. Lower your contrast if need be too. This always solves that for me. There may be a "Black Level" as well.
Mar 29, 2014 | Sony KDF-E55A20 55 in. LCD Television
MY MONITER DELL E771A MONITER SCREEN IS VERY DARK I ALKREADY SAVE 100% BRIGHTNESS HOW TO SOLVE THIS PROBLEM
That's an old fashioned CRT. I'd increase contrast at well since it affects how bright the tones get and see if it helps. It should never be dark. It's may be dying.
Jan 10, 2012 | Dell Computers & Internet
I have a Mitsubishi 60"
there may be dust behind the screen & also on the reflecting glass. u will see that upper back portion cover is removable. remove it & see that glass there is glass on inner side of cover. clean it, also clean the screen. u will see there are 3 picture tubes faces on bottom side, clean all of them.
if it does not work then u can increase brightness of tv by increasing "screen" control of tv which is on the lower back portion of tv. this can be done by any tv repair expert only.
Sep 05, 2011 | Philips Magnavox 51MP392H Rear Projection...
Cannot read screen - screen dark nocnotrast just
To adjust the contrast, turn the calculator on. Press and release the 2ND key. Press and hold the Up-arrow to increase or the Down-arrow to decrease the contrast.
Feb 14, 2010 | Texas Instruments TI-83 Plus Calculator
Caller display screen
Feature *7 will give youo the screen
Aug 12, 2009 | NorStar M7310 Corded Phone
Compaq Presario R3000 dimmed LCD screen
If your inverter is good I,de say your backlight is going bad, I just replaced mine in a sony vaio and now it seams to bright.
Oct 20, 2008 | Compaq Presario Notebook
Screen is Extremely Dark!
Good Day, Cary;
PICTURE IS DARK WHEN OSD CONTRAST MENU ADJUST LEVEL CHANGES.
Cause: SHORTED ZD-309.
Also, increase Screen controls at front of TV and see what pix brightness does . Hopefully you did check brighteness & contast levels. When adjusting Sreen controls set contrast control at about 90% and brightness at about 50%.
Good Luck, big IRISH.
Aug 20, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Dark screen
if the picture is REALLY dark, like you can just barely see it in a lit room, then the backlight might not be lit. LCD TVshave backlight that shines through the LCD screen which allows you to see the picture.
If it's not the backlight then it would be the brightness/contrast settings that need to be adjusted. If the picture used to be normal and all of a sudden went dark, verify the backlight. Normally you can look through the slots on the top of the set and determine if the backlight is on. If you can see a bright light through any of the slots, the backlight is probably OK... go after the brightness/contrast settings.
Mar 25, 2008 | Vizio L37 Television
35 people viewed this question
jasbo
jasbo
