Question about Sony FD Trinitron WEGA KV-36XBR800 36" TV
The green light will not disappear from the screen
Need help with removing the green channel off the screen. Anyone have the instructions.
  • 585 Answers
Press the display button on the remote once to clear it.
Eric
Posted on Jul 31, 2009
I have a pro92,when I press scan it says all channels locked.How do I unlock all channels?
hi glad to be of help follow the following instructions
To remove the lockout from a channel, manually select the channel and press L/OUT so L disappears.
goodluck
Mar 22, 2011 | Radio Shack Pro-95 Handheld Scanner
I m trying to program my RC64 remote for Direct TV and as soon as I press the mute/select buttons in order to put in the codes it says that my remote isn't programed for the TV yet so I cannot press that...
Hi, I work for Directv in the technical department... it is normal for the error message you listed to display on the tv when programming the remote. All you have to do is completely ignore whatever it says on the screen and just complete the remote programming process. I will summarize the instructions for you: First, press and hold mute and select until the green light above the mode switch on the REMOTE flashes twice(can take about 5 seconds of holding down before the green light flashes), then enter your 5 digit code using the keypad on the remote(no matter what it says on the screen-still ignore), after entering the code the green light should immediately flash twice again(that confirms the code was entered correctly), once that happens try pressing the volume up button on the remote, if volume bar displays on the screen increasing the volume then that is the correct code. Once that is all done and volume then works from directv remote slide the mode switch on remote back over to the left under DTV symbol and use remote as normal. Once you change channels or pretty much press any button on remote that is Directv related the error messages will disappear. I usually just press the exit button on the remote in irectv mode to clear the error messages. Hope this helps. :)
Jan 09, 2010 | RCA DIRECTV Satellite Remote Control
PC do not recognize DVD drive and do not show it on screen anymor
It is probably a hardware problem but I would go into the BIOS screen which it gives you instructions when your first booting up on how to do this. One inside the bios screen, which is usually blue, find a list of what hardwares are pre programmed in, maybe under drive managment. Almost all computers have different wordings. See if it listed amogst your hardware, if it is, it may be turned off some how, see if you can turn it back on.
Sep 08, 2009 | Dell Computers & Internet
How to turn off channel number displayed in TV screen
Press " i " (info) button on Sony TV Remote so on-screen display will disappear.
Jun 09, 2009 | Sony FD Trinitron WEGA KV-27FS100 27" TV
HP PAVILLION ZE4900 MONITOR goes 'night vision' green
Just attach an external monitor to it and observe for several minutes while working on it. If the problem disappears, then it's time to check the screen signal cable and/or the screen itself. Only a qualified technician can handle the later except you are one. Good luck
Apr 28, 2009 | Computers & Internet
Power/Standby light blinks green then screen goes blank (off) for
I have a similar problem. Just found out a possible solution yesterday. I am waiting for my lamp but here's what you need to do if you have replaced your lamp. Go into self diagnostics mode: Switch of your TV via remote, you will see red standy by light. Now,on the remote press "Display"=>"Channel 5"=>"Volume Up"=>"Power Button". All these keys need to be pressed within 3 seconds. You will now enter the diagnostics mode. Press "Jump" on remote (bottom right) 3 times and then press "Channel 2" 9 times. The screen will display your current lamp hours used.
In order to reset your tv to factory settings and for the new bulb to work you must reset this timer or else your TV will assume you are still using the old bulb and will automatically kick in "over protection mode". So here's what you do once you do on the lamp hours display screen. Press the "Channel 3" button on the remote 3 times then "Mute" then "Press Enter" to reset the timer to zero. Your TV should now work as normal. And remember, whenever a part is replaced all factory settings must be reset to zero. To do this, follow "Display"=>"Channel 5"=>"Volume Up"=> "Power Up" to enter service mode. Finally, press "Channel 8" and then "Enter" to put the TV back to factory settings.
The above mentioned is usually performed by a service technician and they charge somewhere around $95 diagnostic fee. You just saved this charge. If you see flashing red lights count them when they flash in sequence. This is a code for the techs to tell them what is wrong. These flashing red lights sequentially flash from 0 to 10 times to identify a problem. Usually, when the bbulb goes bad the only thing that might need to be replaced would be a "lamp Driver" aka "Power Block Assembly" $116.25 online from Sony, or the ballast. Sometimes, if you do not have a video a Thermal FUse can go bad which only costs $4.80 for the KDF60-XS955 but the techs will charge you over $300. You can do this yourself if you can get your hands on a service manual.
Hope this info helps.
Good Luck to you all.
Jan 20, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
SANYO MODEL DS27510, CHANNEL DISPLAY IN CORNER WON'T GO AWAY.
If you can program a Comcast remote or another universal remote that has an info key, you can get rid of it. I just succeeded in programming my comcast remote thanks to Dave Taylor:
http://www.askdavetaylor.com/how_to_program_comcast_cable_remote_control.html
Once the remote is programmed, hit the "info" button and watch your frustration disappear!
Dec 05, 2008 | Sanyo DS27510 27" TV
Bright green 3 in the upper right corner of my TV
press the display button on your remote.hope this could help you.u
Aug 19, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Channel information stays on screen for av channels
there should be a info button or display button on remote to turn on and off, unless it is coming from the box that is connected to tv
Jun 02, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
HIDING CHANNEL NUMBER
press t.v., then info button, maybe hit the info button twice. the green channel number will disappear.
Mar 22, 2008 | Televison & Video
Sony FD Trinitron WEGA KV-36XBR800 36" TV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
