Question about Dryers
My dryer gets hot but it dont dry my clothes ,it turns the clothes but thay dont get dry and there is no lint in the filter..please help
    President:
  • 1,714 Answers
Unhook the vent hose from the back and remove all the lint that is blocking the air from going out. Also reach into the back and clear it out too.
Posted on Jul 31, 2009
  • 10,865 Answers
Hello. I am glad you checked for lint in the filter. That could have been a problem. There are several other possible causes Since you did not state whether you had an electric dryer or a gas dryer, I will tell you what to look for in each category.
If you have an electric dryer it could be any one of these things If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
If it is a gas dryer it could be one of these things:Igniter
Gas valve coils
Thermal fuse
My electric dryer won't dry clothes. Doesn't get hot, what's wrong with it?
how is the lint filter maybe it is too full of lint and the dryer will not heat up to protect you from burning doen your house when the lint filter gets too hot and catches fire. Just a thought
Oct 28, 2014 | Dryers
Dryer dont get hot
Try cleaning all the vents inside the dryer all the way to the outside. Be sure and clean around the blower wheel lots of things get in where the blower is pencils nails everything. They will block the wheel so it can't turn. Also vacuum the lint out of the motor. Lint most likely the problem. Hope this helps.
Nov 22, 2013 | Whirlpool Dryers
Lint is stuck in door seal and clothes are not drying
sounds like the lint filter is clogged up, replace it with a new one if possible or give the old filter a good wash, let it dry and try again
Jun 03, 2012 | LG DLE5977 Electric Dryer
Dryer does'nt get hot as expected. 7 years old, takes over two hours to dry load, and clothes have large amount of lint
You need to clean the air filters, must be well and truly blocked up by now.
The filter should be in the door hatch.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | Kenmore Dryers
Slow to dry
Hi!!
Have you cleaned the filter and the exhaust duct??
Lint plugs therm up, the heat sensor shuts off heating element thinking it is hot enough. Result: Clothes not getting dry.
Unplug duct and clean it, also clean the exahust passage of dryer. (where duct hooks to dryer)
Click below if this was helpful, Good luck.
Mar 28, 2010 | Dryers
Drum turns and you feel some heat but does not dry clothes
check to make sure you have no lint buildup in the drier itself along with lint build up in the exhaust hose leading from the back of the drier. If there isn't proper exhaust from the lint filter to the outside of the house or apt. then the clothes will get hot but still be wet.
Hope this helped
Dave
Mar 02, 2010 | Frigidaire GLER331A Electric Dryer
The dryer stayes full of moisture and is not drying the clothes. It gets hot but not dry? Help! I just bought this dryer last night. thanks Michaele
Clean the lint filter and the exhaust line is full of lint too. Unhook it from the back and pull the lint out.
Nov 05, 2009 | LG DLG2525S Electric Dryer
Getting Hot, but not drying the clothes
there has got to be some restriction in the vent system. Take the vent pipe completely off and look in the tube coming directly out of the dryer. Also make sure the drum is turning good speed.
Jun 07, 2009 | Dryers
Whirlpool dryer wed5700sw
you need a dryer vent brush first,bought at home depot cheap,and clean the entire vent to the house,then clean where the vent hooks up to the machine,if your filter is where your door is pull out the filter and stick the brush in there and pull out lint,also use your vacume,remember you let some lint out when you let the hose blow out but theres a lot more there to clean,and also unplug your machine as you do this,if this helps please give me a fix ya vote
Jul 14, 2008 | Whirlpool Dryers
Heating, draining water(enough?) but not drying clothes, they're just HOT, so is top of machine
You have a problem with the condensing duct.  Possibly clogged with excess and lint and needs to be cleaned out.  This requires disassembly of the unit to get to it.  Not a difficult job but not easy.
Oct 22, 2006 | LG WM3677HW 3.7 cu.ft. Front Load Washer...
Dryers Logo
Top Dryers Experts
