SOURCE: Flat panel displays half screen, mirrored on bottom half of screen
Have several problems with either a bad LVDS cable from Main unit to the LCD controll bd. Sometimes the cable is just not connected properly. If you reseat this cable and the problem still exists you most likely have a bad LCD control bd.
SOURCE: desktop view alignment
right click on your desktop and change the default resolution try 800x600, 1024x768 see if that helps. if it does not download a new videocard driver specific to your computer.
SOURCE: GoTo Problem
Be sure that the telescope is configured for EQ SOUTH mode to tell it is in the southern hemisphere. Once a star alignment is completed NEVER manually move the telescope. Use only the control panel to slew. Everytime the telescope is move by hand, the motors do not know it has been done, and assume it is still pointing at the old direction. Check the manual for setup.
Here: http://www.celestron.com/c3/images/files/downloads/NexStar_SLT_manual.pdf
SOURCE: unidentified image, image too large
Try formatting the memory card (or changing it). You probably have some bad sectors.
If this does not help, take the camera to a Canon dealer, it's probably a software problem
SOURCE: Picture image out of alignment
Your viewfinder, focussing screen, and mirror are out of alignment. You need a service technician to fix the problem.
Hi JDRJR35,
Here is the internet address on the usewrs manual for your LCD TV.
http://tv.rca.com/RCATV/RL/1652880A.pdf
Now I will read through it and write down the procedure t be sure you get what your need. See my next post in a few minutes.
