Question about Polaroid i737 Digital Camera
Card error My camera reads card error everytime I turn it on, plus it only holds three picture internaly. It is a polaroid i737 digital. It is not that old at all. I only used it a couple times
  • Zach
    Zach May 11, 2010
    have you tried formating the card from the computer?
  • 33 Answers
The internal memory is very small, so that is normal. Make sure the switch on the card is set to unlocked. Also, if the card is over 2GB, it is not compatible with this model, you'll have to try another one. Make sure the card is inserted correctly and that it clicks into place. Verify on the camera screen by checking for a picture of a memory card just under the battery icon. If it says IN, the camera is not reading the card.
If nothing else works, backup your photos and format the card. This will erase all data on the card. You can format the card from the setup menu. (Menu > Setup [Wrench icon] > Format > Yes) Make sure not to use the card with other devices at the same time, it may leave data on the card that the camera cannot read properly.
If none of this helps, see if the camera works without any card. If it does, then the card may be defective, try another one (noting above size limitations).
Posted on Aug 23, 2009
My Polaroid i737 will not connect to my computer.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Dec 04, 2010 | Polaroid i737 Digital Camera
Our polaroid digital camera i737 displays "Card Locked". We have checked the obvious in that the SD card is not locked and tried the card in other cameras and it works. Suggestions?
Somehow the card is set to read only in the software in the Polaroid. You will need to download the pictures onto a PC and then try to reformat the card in the camera. If that fails reformat on a PC and then try formatting in the camera. If that fails you will have to get another card.
Jan 03, 2010 | Polaroid i737 Digital Camera
I have i737 and when I take one picture it says that the memory is full. I don't have a sd card yet.
The internal memory is very small...if you have the picture quality set to its highest setting, one picture may fill it up. Get an sd card.
Dec 22, 2009 | Polaroid i737 Digital Camera
I have polaroid t737 i lost the cd drivers and
Greetings,
I would take out the SD memory card and use it with a card reader like this one: http://bit.ly/5fruhB . You simply take out the SD memory card and put it in the card reader. Then put the usb end of the card reader into your computer and download the pictures that way.I also recommend that you download Picasa, a free photo organizer/editor for your pictures: http://bit.ly/5f6HEt This way you bypass the lousy Polaroid software altogether. Hope that was helpful,
Take Care,
-WN
Dec 17, 2009 | Polaroid i737 Digital Camera
We have a Polaroid I737 and the SD card is
On the left hand side of the card there should be a small tab (white most the time) You can slide this little tab up and down, In your case move it to side that does not say LOCKED or just the other side.
The lock on SD cards are for protection. Just in case you have pictures you don't want to get erased by accident,,,Just move tab to locked again!!!
Hope this information helped you out!!!
Oct 16, 2009 | Polaroid i737 Digital Camera
I can see all the pictures on the SD card when viewed on the camera - but when I try to download the card (with a card reader since I lost the cable) it only reads some of them
try and when u veiw them on the card reader just drag them on to the computer and saved them and if this problem consist the see if ur under warranty
Oct 14, 2009 | Polaroid i737 Digital Camera
Why would my camera say card locked and wont take pictures
Check your memory card, See if ther is small lock on card, and set this unlock. so you can take the pictures.
If This is not to issue. Remove the card, remove the battery.
Install card , install battery, turn on see if worked. Not Your memory card could be faulty. Check on computer card readers and after you upload the pictures from the card, Format the card.
JMC
Aug 16, 2009 | Polaroid i737 Digital Camera
Polaroid i737 usb cord
I was in need of a new USB cord for my Polaroid i737 as well. This was a problem for me because thee SD card I use with my i737 is a HC card and can only be read by/through my camera. Thankfully, I managed to find one on E-bay and purchased it.
However, if you are using a non-HC SD card for your camera, I would suggest just using an SD card reader to transfer your photos from your card to your computer.
Jun 23, 2009 | Polaroid i737 Digital Camera
Icant download pictures from my polaroid i737 camera to vista
go to the file on your camera where you know the pictures are and drag and drop or copy and paste all the pictures into a folder you put on your desktop or where ever you want it.
Feb 23, 2009 | Polaroid i737 Digital Camera
Polaroid i737 Digital Camera Logo
123 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
