Question about Sony FD Trinitron WEGA KV-34HS420 34" TV
Will not stay on , sound only for 3 seconds then turns off. Stand by timer light blinking
  • ssotelo Aug 05, 2009
    I counted the blinks , mine is blinking 7 times any idea what that means ?
  • 585 Answers
Sony blinking lites are error codes, on an LCD proj set 3 means bad lamp, 4 a bad fan 9 a bad thermal fuse, on a direct view like yours its probably 4 or 5 blinks indicating a bad D board (sells around $250) .
or a bad video IC, so B4 you buy a D board you need to check the CRT board if it has one IC on it measure ohms across the B+ capacitors on the CRT board, if shorted the IC is shorted and also the supply resistor will be open on the D board, if its shorted the CRT may be NG.
If the CRT board has three ICs don't bother checking eem just get the D board.
Eric
Posted on Jul 31, 2009
  • Eric Rotmil
    Eric Rotmil Aug 04, 2009
    Correcting myself, 3 blinks means lamp door switch isn't closed.
Sony tv will not turn on stand by timer light blinking
Try as suggested to count the blinks to see if it is an error code or not. blinks will be in a sequence with a pause and blink the same number of times over and over.
Apr 29, 2012 | Televison & Video
The TV will not turn on. Stand by/Timer light just blinks...
well it's due to ur cable connection is unable to receive or ur dish tv
Mar 28, 2010 | Sony KV-35V68 35" TV
I have a Sony Wega KV-34HS420 TV that takes several tries to turn on. When I push the power button or remote power on I hear the normal click and the sound comes on for 3-5 seconds but then I hear a second...
Since the set appears to "recover", it suggests either a poor solder connection or bad cap somewhere in the power supply. The 7 blinks indicate the problem circuit is in the horizontal area. Check the regulator (STRxxxx) IC in the power supply. If you do not have experience working with TVs, please refer this repair to a shop. The regulator IC costs around $25.
Dan
Nov 16, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Reset timer on jvc dla g150c projectorlamp
1 Turn on the MAIN POWER switch to go
into stand-by mode.
In stand-by mode, the STAND BY indicator on the
projector lights up.
2 Press the following buttons on the
projector, sequentially.
1 Momentary press the PC button.
2 Momentary press the ENTER button.
3 Momentary press the EXIT button.
4 Press and hold the HIDE button for two seconds
or more.
* During this sequence, the STAND BY and OPERATE
indicators alternately blink about every approx. 3 seconds.
After completion of the sequence, the STAND BY indicator
alone stays on.
* Buttons must be pressed within 2 seconds of the previous
button.
* When you make a mistake in button operations, return to
the beginning of the sequence.
* To check the lamp time on the menu, press the MENU button
and select “Information” with the cursor button 5 or ∞.
The lamp use time is indicated in the item “Lamp time”.
Sep 30, 2009 | JVC DLA-G150CL Multimedia Projector
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
Feb 10, 2009 | Sony KP-57HW40 57" Rear Projection...
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The screen stays black when the power is turned on. the stand by/timer ligt blinks
There is a high voltage, and or scan failure. This can be the flyback assembly, and or other support components. If the CRT is defective, it can cause this type of shut-down.
The cost for servicing this would be fairly expensive. It would be best to start shopping for a new set.
Jerry G.
Oct 17, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Jul 18, 2008 | Sony KV-35V65 TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony kdp-65ws550 stand by problem HELP.
You tv needs repair this is no easy fix it yourself thing, take to repair shop.ThankYou for using FixYa . Have a Nice Day.
Feb 08, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
Sony FD Trinitron WEGA KV-34HS420 34" TV Logo
323 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
