Computers & Internet Logo
T
T M Stroud Posted on Feb 22, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I go about arranging for my landline to be moved from he bedroom into the lounge?
Terry
Level 3:
  • The Master 11,377 Answers
  • Posted on Feb 25, 2018
Terry
The Master
Level 3:
Answers
11377
Questions
Helped
4622737
Points
152765
If you own the property, that is your right.
If you must ask a landlord's permission, then do so.
1 Related Answer
Anonymous
  • 44 Answers
  • Posted on Jan 15, 2011
SOURCE: PS3 used to work on
I believe your Lounge TV is an HDTV and your Bedroom TV isn't, This is what you have to do:
1. Connect it to
your Lounge TV with an HDMI cable and a red/white/yellow cable.
2. Turn it on and go to the display settings and switch it to the composite cable setting.
3. Change your TV channel where you would see the red/white/yellow cable and accept it that way.
4. You should be all set. Take it to the regular TV and connect it with the red/white/yellow cable.
cheers :)
I hve 2 fujita units one in lounge other in bedroom do i need 2 remotes i cant turn on the one in bedroom?
If they are the same model you only need 1 remote but if they are not same model you need 2 remote each remote has diff. frequency and build for specific model.
I have a sky hd+ box in my lounge and wish to make the sky work in my bedroom, I am happy to only watch what is on the lounge tv in the bedroom (not have multi room) thanks Nigel
Run a coax cable from the sky hd+ box at the rear from the RF2 coax port, and into tv in bedroom.
If you want to change channels, buy a magic eye from eBay for a couple pounds, enter sky settings, and turn power on to the RF2 output. this will supply your coax to bedroom with 9v which will power your magic rye
PS3 used to work on TV in bedroom and on TV in lounge, now it won't work on TV in bedroom
1. Connect it to
cheers :)
Have purchased new 37" toshiba.
Check the lead from the lounge to the bedroom is connected correctly. The blue screen means no signal.
I have three tvs in my house all off the same ariel.The tv in lounge ok as is the one in 1st bedroom.In our bedroom keep losing signal, have had a booster fitted recently.
I expect the connections could be in need of attention. Check the point where they are connected via that booster. If you have a portable to test the bedroom and rule out the tuner in the bedroom TV?
Hope that helps.
LOST BBC CHANNELS
You need a 45 mg booster to gain the arial signal. Regards, Dave
Top The Computers & Internet Experts
Alexander
nexrad_chris
vince
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
