Question about HP LaserJet 2840 Printer
My HP2480 is making a loud draging noise as like a wheel is worned out. What should I do?
  • 99 Answers
That noise is caused by the DRUM (IMAGING UNIT)
IF it is fairly new you should return it to the store but if it is out of warranty now you gonna have to wait until the drum life expires or if you cant stand the noise then BUY A NEW DRUM......And you will have a peace of mind again.
Posted on Aug 01, 2009
Makes a loud noise when running
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Apr 23, 2016 | Dryers
What makes my mountaineer make a really loud noise after i drive it a couple miles and it warms up
Liz; worn,dry, faulty wheel bearing noise usually get worse as you drive.
link below may help diagnose noise, press the helpful button
Symptoms of Worn Wheel Hub Bearing KnowYourParts
Jan 22, 2016 | 2006 Mercury Mountaineer
My mountaineer makes a really loud noise after I drive it and it warms up what could be the problem
Making loud noise
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Apr 30, 2015 | Dryers
What is making mywhirlpool/admiral electric dryer sound loud and thumping noise
You dryer belt may be shot and a piece of rubber is missing making it jump while working. Needs replacing before it completely quits. It will eventually just break apart.
Apr 13, 2015 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Bosch WTA 3510 uc/13 FD 8203 compact dryer is very loud. Motor is okay. Just changed the main pully. Belts are okay. Still is a loud rumble when operating. Any ideas? Rear bearing appears to be ok
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Oct 09, 2014 | Dryers
My Kenmore dryer model #110.9757 is making a loud noise
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Oct 07, 2014 | Dryers
Worn out colum or gear box
go to the junk yard and find a used gear box, and replace it..
Dec 31, 2009 | 1997 Ford F350 Crew Cab
Loud noise sometimes ocurs when excelerating or braking. sounds like metal draging , but it is not.
Does it make a thudding sond on the shifter....Frist off is it 6-speed or auto, and is it a 5.7/z28/ss or base model...Could be rear tranny mount which is located on the crossmember of the car...If you put it in drive hold your foot firmly on the brake and accel, slowly only to about 2krpms, have a friend look under the middle of your car and watch for the trannie to buckle up towards the back half shaft.....Get back at me with this info..I own 7 camaros, i can def help you w/ this....
May 13, 2009 | 1998 Chevrolet Camaro
Is the car stick shift or auto. Sound like a problem with either the transmission which is spinning all the time even when sat still. Or the Rear axel is tuffed out..
May 12, 2009 | 1985 Chevrolet Camaro
HP LaserJet 2840 Printer Logo
233 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
