Question about HP Pavilion F1703 17" LCD Monitor
LCD monitor Hello,I got an F1703 monitor on eBay. It worked all right for a day or so, then the picture became washed out, especially on the bottom, with fine white(or black) lines visible. The OSD controls have little or no effect. The power supply seems OK(16.75VDC). In a dialog box, there's a figure of 8.5K hours. If that is total running time, is that a lot?I'd like to try and salvage it (I'm quite familiar with a soldering iron) and read somewhere that bad capacitors can cause such problems. Do you think that this, or some other "fixable" problem could be the case here?
  • MikeFarad Feb 24, 2008
    Caps look OK. Board looks clean, and I re-soldered any questionable joints, but still have problem. Your suggesting a bad cap(s) sounds good, so I'll try replacing all the electrolytics on that board.
    Thank you very much for your response.
  • ErnGotti May 06, 2009
    I dont solder nor do I know what the Invert pcb is. What do they look like?
    Champion:
  • 220 Answers
Normally TFT monitor backlights have a life of around 40,000hrs .Open up the monitor and check visually for bulged leaky capacitors.This monitor is reputed to fail due to dry solders on Inverter pcb.
Posted on Feb 19, 2008
HP Pavilion F1703 goes black after 2 - 3 seconds
Resolder the leads of the four TOROID inductors, make sure to remove the old solder, clean the leads real well and resolder. Also check caps for leaking/bulging tops and bottom seals, check the transistors (c5706/5707) for shorts.
See my pictures here:
http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
Basic LCD monitor and LCD TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find
Nov 14, 2010 | HP Pavilion F1703 17" LCD Monitor
HP f1703. After a power outage, when computer is
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 19, 2009 | HP Pavilion F1703 17" LCD Monitor
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
I need the cord that fits the hp f1703 minotor , that is the one that also powers the speekers. Where can I find what I need. john
you can purchase it from ebay @ http://cgi.ebay.com/12V-LC-4Power-as-AC-Adapter-power-for-HP-F1703-LCD_W0QQitemZ8826198355QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
Jan 29, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor screen is black when hooked up to my laptop.
u have to set screen resolution of monitor to 1024 *768
Jan 05, 2009 | HP Pavilion F1703 17" LCD Monitor
I hooked up my monitor to my Sony Viao laptop.
when upower up press F8 key also check there u set laptop as primary dispaly and second as monitor.
Problem with FPD1760 Gateway monitor
sounds like the LCD inverter gone bad.
you might get lucky in finding one on EBAY.
yeah gateway sucks on customer service.
Jun 18, 2008 | Gateway FPD1760 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
120 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
