Our eiki eip-2500 projector has stopped working. we have a red led lamp light lit. any suggestions? Lost in ohio
  • 69 Answers
That would mean protect mode. something at some point in time overheated and is now more than likely burned out.
Posted on Jul 31, 2009
Where can I find a service manual for the Eiki EIP-2500?
difficult to find online, try comparable model of SHARP XG-MB55X
May 24, 2012 | Eiki EIP-2500 Multimedia Projector
How to remove top cover of Eiki EIP-2500 projector
loosen all the screws from the bottom ( one is in the middle) and two at the back ( edge)
press the grill on exhaust fans side near the heat warning mark.Lift carefully the rear and turn towards the lens side, BUT BE CAREFULL that some points of the upper cover will not scrape of some smd parts from the mainboard !!
I had a bulb burn replaced both bulbs worked for a couple of days but now it wont power up only lamp1 light blinking. I have tried taking bulbs out and putting them back in still nothing, also the lamp...
the lamp units should be properly aligned with the 2 very tiny switches
between them. If not lamp led will blink.
If lamp led is continuously on, lamp timer has to be reset, according instructions that come with new units.
Original lamp modules are AH-45001 and AH-45002, two different
units needen for 1 projector, reset procedure is different for each lamp !!
Dec 21, 2010 | Eiki EIP-4500 DLP Projector Multimedia...
I have both the stand by and lamp indicators flashing then the lamp liight goes to a red The lamp never actually lights up in this time.The globe has only done about 250 hrs.
The bearing of the colourwheel is locked. No rotation of colourwheel possible, then also no lamp ignition. Colourwheel has to be replaced.
Nov 06, 2010 | Eiki EIP-2500 Multimedia Projector
I have an EIKI EIP-5000 it starts normally but a minutes later it stops working and the temp light turns on. also the screen has some displaced pixels like when a video card is broken. also this...
This happened to me. In the projector, the section in between where the lamps go, there are two very small switch type levers, when a new lamp is positioned, these switches are supposed to move in line with a 4mm section of the new lamp. If they are not aligned together with the switch and slotted into place, it appears as if the projector doesn't recognise the new lamps. Unscrew the lamps again, make sure these little switches are aligned (a very small screw driver could help while positioning) when refitting the the lamps. Screw the lamps tightly and fire up. Hope this helps.
Nov 03, 2010 | Eiki EIP-5000L 5200 ANSI Lumens DLP XGA...
Need a new remote control for a EIKI EIP1. How do I order one? I am in Perth Western Australia
Hello, I couldn't find any remotes available for this projector.
Try contacting Eiki directly with the form on the page below
Click here:http://www.eiki.com/ContactForm.aspx
Sep 20, 2010 | Eiki EIP-2500 Multimedia Projector
Remote won't turn on Eiki EIP-2500 projector
Try cleaning the IR port on the projector (and the remote itself). These can get enough of a dust layer build up that they can't "see" the infrared signal being sent.
Feb 08, 2010 | Eiki EIP-2500 Multimedia Projector
I thought my light went out on my Eiki projector, it is a eip 2500. I replaced the lamp, but it still will not power up. I tried a different plug and still no power.
if there are no leds on the top, replace the power supply. if the leds are on and the fans are running, it may be the colorwheel or the ballast.
Jan 06, 2010 | Office Equipment & Supplies
No power to Eiki EIP-2500 projector
there is a fuse on the power supply. if the fuse is good, you'll need to replace the power supply.
Jun 22, 2009 | Eiki EIP-2500 Multimedia Projector
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
