Question about Acer Aspire One AOA110-1588 Notebook
Runs when fuel is poured in carb - Acer Aspire One AOA110-1588 Notebook
  • Acer Master
  • 32,281 Answers
Sound like your fuel pump is not working or you have a blockage in the fuel line.
Posted on Jul 31, 2009
Car will not run unless gas in carb
Sounds like the fuel pump is bad. The engine is just not getting fuel unless you pour it in the carb.
Apr 12, 2014 | 1984 Lincoln Town Car
Engine stalled out,would not start, pour gas in carb,cranks,keeps running,until idle falls below 12to1500rpm,than stalls out again and will not crank,repeat gas or starting fluid in carb,cranks runs and...
This truck is fuel injected, the problem sounds like a weak fuelpump, it runs when you pour gas into it until that gas runs out, the first thing is to test the fuel preasure, if the pump is weak it may run with gas poured into it but wont idle, also a common problem is the coolant temp sensor and the ground wires to thermostat housing bolt but i wont bet its the pump inside the fuel tank, if you put a fuel gauge on it there should be at least 55-61 psi if its a few pounds lower it can cause problems, you have everything else and it runs with gas poured so its a fuel problem check the preasure, theres a valve up top on the fuel line to connect a fuel gauge to it, start there hope this is helpful.
Dec 27, 2010 | 1993 Chevrolet C1500
066 saw will not fire no fuel good spark. I have new fuel filter and line from tank to carburetor. I have tried another carburetor still nothing. I poured fuel in carb engine fires but won't run any...
You need a new carb, plain and simple. If it runs when you pour it in, the engine and coil are good. It doesn't make any sense to rebuild a carb unless it's like a 2-300$ carb on a large machine. On a two-cycle chainsaw, it's maybe 40-60$ for a new carb, versus a 20-30$ kit, plus labor (yours or theirs) and it's STILL going into an old, worn carb.
Sep 28, 2010 | Stihl Garden
20 hp craftsman lawn tractor (2006) stopped running while mowing. tried to restart . ran for 2-3 seconds and quit. could not restart. fuel running free through filter all the way to carb. pouring fuel in...
I would take the bowl off the bottom of the carb.. Probably you have clogged up holes that let the gas into the bowl.Or either the needle is stuck up not allowing the gas to flow...That's why pouring gas in carbs would let it run for s few seconds....Also try fresh gas..Gas doesn't have led in it anymore..It don't last year from year...After grass season is over..Buy some from Lowe's or home depot..Pour it into your tank and let the motor run to get it done into the carburetor...Then the next year it will start
Jan 12, 2018 | Craftsman 20 Hp 42" Deck Lawn Tractor
Wont run, not getting fuel. disconnected fuel filter, still nothing. Can spray a shot of carb cleaner directly into carb, and will run until it burns the fuel then dies. Check and getting good spark.
you say it's not getting fuel? when you bypassed the filter was gas coming out of the fuel line right where it connects to the carb? If it runs on ether, carb cleaner or pouring fuel in the carb then your problem wont be the the carb or motor it will be something like a cracked, dryrotted or pinhole in the fuel line. Or something restricting the flow from the tank to the carb.
Aug 04, 2009 | Mantis 2-Cycle Tiller
Fuel not getting from fuel tank to carb
I hate too tell you this But, It IS The Fuel Pump if you can Start it By pouring Fuel into the Bowl. Please Rate my response, I need all the help that I can get! Thanks!
Jan 26, 2009 | 1985 Buick Skyhawk
Acer Aspire One AOA110-1588 Notebook Logo
16 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
