Question about Windchaser PAC8 Air Conditioner
Appears to operate but will not cool - Windchaser PAC8 Air Conditioner
Posted on Jul 31, 2009
Air pockets in coolling system
Sometimes air pockets form in the cooling system when the coolant has been drained. The will result is engine overheating. This happens even after the coolant has been added and the cooling system appears to be full. Air can enter the cooling system after changing the water pump or lower radiator hose. This will affect the engine's ability to maintain proper operating temperature.
http://www.writeversity.com/
Apr 16, 2016 | Cars & Trucks
Whirlppol Side by Side no longer cooling well.
I'd suspect a failed thermostat in the fridge compartment, a split and sagging door seal, or a fault on the microprocessor control if it has one of those.
Feb 10, 2015 | Refrigerators
What does e3 mean on a Samsung microwave
Temperature of exhaust air too
High
Let it cool down?
Cause:
The oven cavity gets too hot due to excessive
operation with no load or small load, or due to
some blocking materials around the Air Filter or
Air Exhaust at the back of the oven.
Remedy: • Open the oven door and check if 1) the oven
has been operating with no load or too small
load, 2) the air filter is placed in a wrong
position, or 3) any blocking materials exist
around the Air Exhaust. Cool down the oven (for
approx. 30 min) under the normal temperature.
The oven is back to normal when the error
code "E3" disappears and "ON" appears again
in the display window.
• Unplug the power cord, remove the blocking
materials around the ventilation openings, cool
down the oven (for approx. 30 min) sufficiently,
plug the power cord in again and check if the
error code appears again.
• If the symptom persists even when the oven is
cooled down sufficiently, contact the nearest
service centre
Jun 26, 2014 | Samsung MW1080STA Microwave Oven
HPCO ACTIVE APPEARS ON SCREEN
Fan is not operating properly (if air-cooled model) or No cooling water (if water-cooled model) or coils dirty (overheating)
Jan 27, 2013 | Manitowoc QD0452A Ice Machine
When i turn on my new h p notebook a cooling fan not operating right warning appears. and if i dont push enter it turns off my notebook
you have to consult your engineer to check the cooler fan if it is properly seated on the motherboard or connected tightely
Jan 05, 2011 | HP (344872-001) Laptop Cooler, Cooling Fan
I have an evaporative cooler: vulcan bonaire. the only control buttons which appear to be useful are: on/off, cool in the 'appliance' window, and cool in the 'mode' window. i have a feeling that this is...
Hi and welcome to FixYa. The principle of operation of an evaporative cooler is to provide cooler air via evaporation. The evaporation process is achieved by water being pumped over very porous pads with air is drawn through the pads. Most all evaporative coolers unless connected with a centralized heat / cool system only have an on / off & cool function. "On" is fan only (air circulation while using outside air being drawn into the home) and "cool" turns on the pump to pump water over the pads for evaporative cooling. Hopefully I did not confuse you with my answer.
Happy New Year and thanks for choosing FixYa,
Kelly
Jan 01, 2011 | Heating & Cooling
Fujitsu inverter; opens vents but no red light, no cold air
check that it is set to cooling sounds like it may be set to heat in cooling mode the indoor fan should at least run
Mar 10, 2010 | Heating & Cooling
Refrigerator not cooling very well, upper freezer appears tobe ok
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 29, 2009 | Kenmore Refrigerators
Appears to overheat
Have you determined that you're cooling fan is operating? If so, check to see if your coolant level is full. If not, your fan switch is not operating properly.
Jun 13, 2008 | 1998 Plymouth Grand Voyager
Windchaser PAC8 Air Conditioner Logo
254 people viewed this question
Top Windchaser Heating & Cooling Experts
Jay Finke
Jay Finke
Donni Steen
Jake's Auto Care...
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
