Question about Westinghouse Televison & Video
Will not turn on with side controls or remote.
Will not turn on with control on set or remote. Sometimes comes on spontaneously. Comes on with white screen. When it comes on spontaneously I turn remote control off and then on again to access video function. Not connected to cable. Using for DVD play only. Sleep set says it's off. Has been known to come on by itself after a power outage has been restored. Recently hooked up to Sony stereo receiver to boost volume. Purchased 11-07 at Best Buy. Westinghouse tech support number "temporarily disconnected".
  • 585 Answers
Sounds like a bad main board,but try this 1rst since the only easy fix on these is check the power supply for swollen capacitors and clean the LVDS cable and reseat it (goes from the main board to the panel)
Posted on Jul 31, 2009
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
Jandy one touch control panel model 8156 - spa turns on when pool is on
if you have a 4 button spa side remote unplug if it goes away replace spa side remote
Aug 03, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Intermittent error. Remote inactive with volume bar on screen. Volume can be increased manually but returns to zero spontaneously. Power off and on occasionally and temporarily fixes problem.
Tries tv unplug,replug it back like about an hour later.Go into tv menu goto PICTURE go down to do resetting.To resetting the tv Tuner signal board back to factory setting,now it should be working a gain.If still have the same result.Than the manual control PCB board like power,volume - + so on.. is short and the causes.Tries wwebsites like Shopjimmy.com,Ebay.com to buy a furbish Manual control PCB bosard for the replacement.
Feb 05, 2011 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
My headlights intermittently will not come one. Sometimes it is the passenger side, sometimes it is the driver side. After a while they may both come on spontaneously. Could it be the ignitor or control...
Hello. Begin by removing both bulbs, cleaning them with contact cleaner, then cleaning the bulb sockets. Reinsert the bulbs. Check it out. IF it still a problem, then check the module.
Jun 09, 2010 | 2006 BMW M3
Refrigerator side light is out, but the compressor sounds like it's still running, plus the food is still cold. Interesting, when I turn the control knob to off, the light comes back on, but the compressor...
have never seen a ref of this style with a control board I would say you have some sort of wireing short. if the control is turned off the lights will still stay on, but they also should be on when if running
Apr 23, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
When I turn the light off with the remote control
im realy not trying to be a smart a*s but bont you only ever use lights at night?? i know i do?
it sounds like its the programer chip within the light that giving you the problem if taking the batterys out the controler dont stop this, its down to the light,
well there is one other thing it may be,,,
a friendly gost playing tricks on you???
or it could be that its getting a surge or spike of power from some were and that tricks the controler in the light to turn itself on???
sorry about that bit of fun as first just could not resist it????
Oct 26, 2009 | Hunter Ceiling Fan Light Remote Control
We have a Milano Model No. F527 fan. The light comes on spontaneously at random times and the fan can only be turned on and off sometimes. Other times it works perfectly. The remote control batteries are...
Get in touch with Minka group Mr. Minka who will assist. I'm working on my same problem right now. You need to reset the dip switch in your remote or wall switch and also the same setting on the fan.
Jun 29, 2009 | Minka Aire Ceiling Fan
Hampton Bay Ceiling Fan Windward II
There is a 4 position (dip) switch on both the fan housing and the remote. Make sure these switches are set exactly the same and the remote will control the light and fan separately. If not, the remote may be getting interference on the preset frequency - try CHANGING the dip switches to a different setting and the remote should work.
Jun 11, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Televison & Video Logo
83 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
