Question about KitchenAid KSRD22FKBT / KSRD22FKWH / KSRD22FKBL Side by Side Refrigerator
Both refrigerators stopped working.
Both of my refrigerators stopped working at the same time.
There is power and everything seems to be OK. The light is on, the freezer fan is blowing, etc, but there is no cold.
This baffles me to no end.
The only guess that I can make is that the voltage has dropped or that the fridges got overloaded by a voltage spike.
All other appliances in the house function perfectly.
Please help!
Thank you, Dmitry.
  • Kitchenbreak Nov 24, 2007
    Thanks for your reply.
    Yes, I would like to diagnose and fix it myself if possible. I am pretty handy.
    BTW, I shook the compressor and it came on. I saw a spark in the starter relay, but it worked for a while.
    After it got cool and shut down, it never started again.
    What do I do?
  • 447 Answers
So you have two Kitchenaid refigs??? Is one a freezer and one just a refrig?? Anyhow it sounds like it could be the compressor start relay. You will axcess this through the rear panel (usually cardboard). Let me know if you are going to attempt to diagnose the failure.
Posted on Nov 24, 2007
  • joey  shearer
    joey shearer Nov 24, 2007
    That starter will need to be replaced. It is a common failure. Is it a one piece design that clips to all 3 compressor terminals? or is it a 2 piece design that a larger brown piece clips to 2 terminals and there is a flatter overload that clips to one terminal.? Shake the relay. If it sounds as if the internals have littlerally shattered then its bad.
My Lynx 24 outdoor refrigerator stopped running It is less than one year old. Any troubleshooting advice?
Is there power to the outlet that fridge is plugged into. If yes you might have a blown relay that's mounted on the compressor
Mar 06, 2018 | Lynx Refrigerators
Frig freezer wont get cold enough after move . 35 degress then back up to 45 . cleaned everything good . coils everything . worked fine till moved . waited 24 hours after move to plugg in . help
Hi Kim, Before you check out the link below, Read about your refrigerator not cooling?Is your older or newer model refrigerator plugged in, getting power, the lights are on inside but the fridge will not cool and the freezer won't freeze? If your refrigerator or freezer has suddenly stopped cooling and the freezer won't freeze, we have multiple solutions for you.If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor is overheating or not getting proper power and will not start. The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
Refrigerator Is Not Cooling What To Check And How To Fix
Apr 03, 2016 | Refrigerators
GE Profile Side-by-side Refrigerator TFX28PBBABB
Most ge have a Multispeed fan control on board. But if you had to start the fan with your hand, I would guess it would be a fan issue
Sep 08, 2012 | GE Refrigerators
Hi, SAMSUNG SR L39 stops to cool, even if everything seems ok, the fridge is on, the display lit, but food is not cold. Then turn off and turn on the fridge by the power button and everything seems to go...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 20, 2011 | Refrigerators
GE side by side w/Ice Denspenser. #TFX27ZP. Three times my frieg stopped working gradually. after removing everything it began to work again. I have tried to put minimal items in both the refrieg....
It seems as though your fridge is sticking in the defrost mode...try replacing the defrost timer/control...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Nov 01, 2010 | GE Refrigerators
Everything seems to work just fine except the ice maker which stopped for no reason. I have checked everything. The water dispenser works well, the water pressure is more than sufficient. We lost power,...
I know of one trick that might solve your problem . First , make sure the lever that swings up and down during cycle is all the way down . Then , pour one eight ounce cup of water into the ice maker where the slots are . Hopefully , when the water freezes , the ice maker's sensor will detect the ice and start the dump cycle . If it does , and everything is OK inside the unit itself , it should be OK after it ejects the ice .
Oct 08, 2010 | Refrigerators
Hotpoint Mistral Fridge freezer no Power Issue
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} . Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Dec 11, 2009 | Hotpoint FFA80 Bottom Freezer Refrigerator
Excessive frost on coils
newer refrigerators have defrost modules or micro computer circuit boards. the wiring diagram should have test for checking the defost system. by pressing the light switch so many times in so many seconds.
Jul 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool side by side fridge freezer s20-d rbb32 a/g
Either there is a loose connection at that board or in the plug where the wiring goes into the door (should be at top or bottom door hinge). If all connections are tight then replace the board. Not sure how old this unit is but it does come with a one yr warranty from date of purchase.
Oct 06, 2007 | Refrigerators
Whirlpool Refrig Side by side
the problem is almost certainly in the controller or its power supply. Try pulling the plug for a minute or two - for some reason the display portion of the controller may have been sent out to lunch by a power surge or alpha particle. It woudn't be the first time. Check for bad connections between the display panel and the power supply and solder joints on the controller board. With everything else operational, a bad microcontroller chip is not that likely but is still a possibility. Good luck
May 18, 2006 | Whirlpool ED2FHSS Side by Side...
KitchenAid KSRD22FKBT / KSRD22FKWH / KSRD22FKBL Side by Side Refrigerator Logo
75 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
