Question about Car Audio & Video
Im installing a stereo in my 92 subaru legacy but dont know which wires connect to which
  • feng_sara Aug 01, 2009
    Ok but Im not sure which color wires these are
  • 69 Answers
Generally u have 2 power wires. one is a constant power to the battery for backup memory for stations etc. the other goes to ignition. then just the speaker wires and a ground.
Posted on Jul 31, 2009
Free wiring diagrams
google it my good man
Aug 25, 2014 | 1991 Subaru Legacy
2006 subaru outback, missfire code - cylinders 1 and 3. Could it be coil or plugs and wires I'm told at service shop. Anybody come across this?
had miss fires with my 92 legacy gt.typical suby fault coil packs always go out in saying that check that you dont just have a foul or failed spark plug. easy fix if it is the coil i replaced mine with 2nd hand ones from the same model usualy find them at most subaru specialists wreckers etc depending on model.
Sep 17, 2013 | 1996 Subaru Legacy
I have a 92 legacy sedan with bad motor. Bought a 92 legacy wagon turbo. Do I have to change wire harness in front with computor, or can I change just computor?
hi im presuming your old car is non turbo if so you will have to change a lot of parts over to make it work, you will have to replace entire engine loom, the ecu will need changed over then the fuel pump and all of the fuel lines will need to be replaced with the bigger turbo model ones to keep up also the trans will bolt strait up but will be the major weak point so swap over if possible.
Jun 15, 2011 | 1992 Subaru Legacy
Installing aftermarket Kenwood stereo on 1991 Subaru Legacy. The subaru stock wiring does not have a red ignition wire. Can i simply connect the kenwood ignition wire to the Accessory +12v (Yellow/red)?...
Hi, according to my source, there should be an accessory wire that is blue with a yellow stripe. If your is yellow/red, that's fine. You actually should prefer an accessory wire to an ignition wire as there may be less static on the accessory wire. Just make sure the wire does not have power when the key is off. Don't use the illumination wires--they are not needed for the aftermarket head unit and should be taped off.
1991 Subaru Legacy Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red/Green
Car Radio Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Yellow
Left Front Speaker Negative Wire (-): Blue/Red
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Blue/Black
Rear Speakers Size: 6 1/2? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Yellow/White
Left Rear Speaker Negative Wire (-): Blue/Red
Right Rear Speaker Positive Wire (+): White/Blue
Right Rear Speaker Negative Wire (-): Blue/Black
May 31, 2011 | Car Audio & Video
Installing aftermarket stereo. cannot locate a
BEST BET IS TO GO TO A STORE THAT SELLS &INSTALLS.... I,VE HAD THEM MAKE A COPY OF A SCHMATIC BEFORE... ,CHARLIE
Mar 02, 2010 | 1997 Subaru Legacy
I dont know where my thermostat is in my 92 subaru legacy, but i think theirs something wrong with it. I have a brand new adiator, but my car is overheating still?
The thermostat is mounted low down on the bottom of the engine where the large radiator hose connects to the radiator. The housing is bolted to the engine block and the thermostat is inside. Don't attempt to replace it unless the engine is cold otherwise you will burn your hands. Make sure you bleed all of the air out of the system before driving off.
Apr 05, 2009 | 1992 Subaru Legacy
Radio install
http://www.modifiedlife.com/1991-subaru-legacy-car-stereo-radio-wiring-diagram/
Mar 05, 2009 | 1995 Subaru Legacy
Fitting band expander to my legacy
Im trying to put a band expander in my subaru legacy 2000, I got radio out but where is the antenna plug that is at the back of radio?
Nov 03, 2008 | 2001 Subaru Legacy
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
