SOURCE: My DELL Lattitude D820 laptop is not detecting battery
indicates that battery needs to be replaced. Update BIOS if applicable. If no go and battery is within warranty (Dell warrants battery for only one year of its invoice date), contact Dell for replacement. Otherwise, get a new battery.
SOURCE: no power will not charge sccreen flashes white
hello there,
the problem would be that the charger is not sitting properly, therefore it tries to connect but ends up not charging.
try to replace the charhing port of the phone then you can try to charge again. or look for a charger that fits properly.
goodluck
SOURCE: the blue light does not
it might have been dropped, if so it could have bent the little read pin inside causing it to not be able to function correctly, those little harddrives cant take a very big hit
SOURCE: when i try to turn on my kodak MD41 the light goes
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
