Question about AAD E-30 Main / Stereo Speaker
Same thing that glass tube i think is a fuse is blown on mine
I just need to know if that glass tube thing is a fuse what style it is and what you replace it with
  • 69 Answers
Yes that is a fuse.. you replace it with the same type.. the rating of what size it is should be on the metal at either end or bring it to an auto supply store as they carry these.
Posted on Jul 31, 2009
After plugging in-will not turn on?
You may have a blown fuse. You can remove the screws and pull off the outter shell. When you look inside, you should see a glass tube which is the fuse. Inside the glass tube there should be a thin wire that is supposed to run all the way across the tube. If that thin wire is broken or the fuse looks burnt, then it should be replaced.
Jan 06, 2011 | Cyberhome CH-DVD 300 DVD Player
TV blew fuse. Replaced with 125v 5 amp from a 33 inch Toshiba that has gone bad. The 5 amp also blew. Purchased new 4 amp fast blow fuse for unit, now nothing happens, i.e., no blown fuse, no circuit...
replacing the fuses with random values is prolly not a good thing...but one thing to check is a big transistor know as the HOT. This will more than likely be clipped or screwed to a heat sink NEAR the flyback (big transformer, has a wire going into the big glass tube). That causes fuses to blow...If this does not work, let me know.
Nov 30, 2010 | Toshiba 13A23 13" TV
During our last storm my Bernina 170 just died. I had it on a surge protector, but it just doesn't turn on. While I love this machine, I also have a B 165, so I thought I would try my hand at fixing it...
If this is an older model, the power supply module is a little sensitive to mains spikes - I've had three that have suffered a similar fate and all have required replacement power-supplies - the switching transistor gets blown and this is a job only for the qualified service engineer. My suggestion, I'm afraid, is to have it checked-over by a service engineer. There is a glass fuse on the circuit board, but if blown, it's usually for a reason and 9 times out of 10, just replacing it results in a second blown fuse !!!
Jan 18, 2010 | Bernina Artista 170
Heard a pop then screen went blank. Now TV wont turn on.
Sounds like your fuse.
If not the fuse in your plug, then the internal fuse in the TV. to get too this you need to open the TV by taking off the back plastic panel and look at the fuse.
the fuse is the glass tube on the board, will no doubt be near where the power cord connects to the TV. and are easy to replace with another fuse. you will know soon as you open it if its blown as the little glass tube will be blackened or the little wire inside the tube will be missing or severed.
Fuses in TVs are actually designed to blow over time with ware (usually to last a bit longer then the warranty time frame) so after the cover has ended the TV can go in for repair work at extra cost. Its a little known fact.
Jan 02, 2010 | Sony KDF-E42A10 42 in. LCD Television
Can not find 10 amp fuse for the battery charger
I've never had a charger blow a fuse in servicing hundreds of chairs, so I am going to guess you fried the charger. Normally they just stop due to an transistor going out, but a blown fuse is big.
Dec 25, 2009 | Everest & Jennings Metro Power? III Power...
Radio / CD player will not work. Have already checked fuse box....nothing blown. Is there a fuse in the unit itself?
Yes, most stereos will have a fuse in them. Even the older ones had fuses, but most would have been old-style (glass tube with metal caps) fuse. If your stereo is a newer one, they are usually located on the back of the unit itself; look for a blade -type fuse. This would, of course, require pulling the stereo to access the back side.
Hope this helps!
Dec 04, 2009 | 2005 Ford Taurus
Tomtom wont charge
the plug end(cigarette lighter end) may have an internal fuse. the very tip screw off and inside is a small glass tube style fuse. check that.
Aug 08, 2009 | Tomtom ONE 3rd Edition GPS
Green light on but no ac power out
Probably has an internal fuse that is blown. You will have to disconnect it from dc power and take the cover off and look for a fuse that is blown, should be near the AC outlet or on the circuit board. Could be a glass tube or newer style automotive plug in type. Good luck.
May 18, 2009 | Vector ® Maxx SST 1200 - watt Power...
Apple LaserWriter 8500 not turning on
There is a glass-tube fuse inside, near the power switch that blew on mine a couple of years ago. Being the curious type, I popped off the side cover to see if there was any obvious reason, loose connectors, burned resistors, etc., and found the blown fuse. Can't remember where I got the replacement, but think it was Radio Shack. It's a common type.
Dec 12, 2007 | Apple LaserWriter 8500 Printer
AAD E-30 Main / Stereo Speaker Logo
53 people viewed this question
Top AAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an AAD Audio Player and Recorder Expert? Answer questions, earn points and help others
