Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Help i need to fix the timing on my washing maching, during every load it stops at like 3mins or something and never drains the water or finishes the load
  • 98 Answers
Yep, you need to replace the timer disc under the knob....it is easy to do, call a local repair shop to order the part, and install it yourself. OR...you can go on line and order the part yourself. Go to this site...
WWW.Howthingswork.com
it should tell you what you need to know to DIY!! (do it yourslef)
Posted on Jul 31, 2009
Why does it quit randomly during cycle?
If you cleared the drain pump trap of obstructions, and the pump still runs fine(without rattling from a loose or damaged impeller) then most likely you have fixed the problem. The washer will not spin if it can't drain--and if the water is draining too slowly, it will time out and give an error code for "slow drain". For any items such as bras, underwear, socks, baby socks, stockings, pantyhose, etc, use a netted clothing bag with a zipper to prevent those types of things from getting pulled in-between the basket and tub and then making it to the drain pump trap. These things are notorious for clogging pumps on front load and top load HE washers!!
Aug 02, 2015 | GE Washing Machines
Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
Dec 26, 2010 | Washing Machines
Duet GHW9150P Front Load Washer: During washing cycle it stops and beeps with the l...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LSR7233B. Midway during regular wash it stops and
sounds like a bad timer.the part# is WPL285938,cost is $148.35.
Dec 11, 2009 | Whirlpool LSR5132PQ Top Load Washer
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Oct 09, 2009 | Maytag MAH6500 Neptune Front Loading...
I wanted to take some clothes out during the cycle but don't know how to stop it properly and get the door unlocked
your mach depending on model and cycle selected has a 3 to 5min "add a garment" feature.that means in the 1st 3-5mins of cycles when add a garment light is lit you may hit pause button once and the mach will stop and unlock door.after add a gament light is off,if u hit pause the cycle the mach will drain water and reset cycle..hope this helps
Mar 29, 2009 | Kenmore 42822 Front Load Washer
Washing machine stops when there is 19 minutes left!
you need to have a tech out to look at it it sounds like the motor isnt going into high spin and /or cutting out on over load this is a problem with the g/e's there is no filter on this machine all the lint is flushed down the drain
Jan 08, 2009 | GE WBSE2090A Top Load Washer
Neptune-is water supposed to remain, after wash is finished, between tub and outer shell
if you hear water when you spin the basket,that is the front tub balance ring.it is filled halfway with water in order to assist mach in balancing load.that is a normal sound.the mach may also leave some water between the basket and outer shell depending on lengh of drain hose.as long as the clothes do not come in contact with the water it is fine.
Sep 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Will not finish draining
i have amagtag neptunetl washingmachine and it won't drain the water all the way out nor will itspin out anything.it is computerized.sure could use your help
May 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
66 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
