Question about Refrigerators
Samsung RB1955SW refrigerator error code -2 / 44
After reset it works just fine temps go down for both sections until something causes it to stop cooling and then I get a reading of -2 and 44 for temp readouts which is inaccurate, Restarting system reveals real temperature and starts cooling again Is the -2/44 reading an error code
  • Kevin McNamara Feb 22, 2018
    Perhaps I've given you the wrong impression, The temperature inside the box displays when you reset the cpu. At that point actual temperature is being displayed and I can restart the power cooling systems. Box runs fine lowering temp in both boxes untill I find it once again displaying -2&44
    Loyalty:
    Visited the website for 30 consecutive days.
  • Refrigerators Master
  • 545 Answers
I think that is your temperature setting that you set it it or could be the temperature in the case
Posted on Feb 22, 2018
SOURCE: Car starts fine when cold,when
Have you figured out the problem?
Posted on Sep 12, 2008
  • 116 Answers
SOURCE: Inaccurate temp gauge
change the thermostat it is stuck open
rank & vote
Posted on Dec 16, 2008
  • 25 Answers
SOURCE: Temperature gauge problem on a 1987 Samurai
There's two sending units in the intake. The little on with single prong at the t-stat housing is for the guage and the bigger one plastic connector is for ecm.
Your signal is getting grounded somewhere.
Posted on Mar 17, 2009
wyet_helps
  • 510 Answers
SOURCE: electric cooling fans not working
{: ) You didn't mention the model of your vehicle. Anyway, I admire your way of observation, and I'm sure you got the analogy by now. When the car is running, the engine rpm is higher, and so with the water pump, plus the wind velocity passing thru the radiator fins, can give sufficient engine cooling without the electric cooling fans. But when your vehicle stops, like sitting on a traffic, the engine rpm is lower, and so with the water pump, and there ain't enough wind to help.
This is why the electric cooling fans are very important in maintaining engine temperature at normal levels in any driving conditions.
Basically, the cooling fans are controlled by the engine control module (ECM). The ECM monitors input from various engine sensors and then will give an output signal based on its programmed instructions. The output signals will energize the corresponding fan relays, be it high or low speed.
You can start by checking first the easy ones like the fuses and relays. Cooling fans usually have square top transparent windows. Check the the underhood fuseblock label to locate. Might as well check all fuses to be sure.
Check the cooling fan relays for signs of overheating, and also for loose terminal seating.
Check the cooling fan if stuck, and also check the connectors if burned or melted. To rule out a defective cooling fan motor, you can check for continuity, or you may apply direct voltage to the two wires on each fan.
The mostv frequent cause of cooling fan malfunction is on the fuses, relays, and connectors.
Posted on Jul 22, 2011
dmsr63
  • 2050 Answers
SOURCE: My 1999 Chevy Malibu runs hot? It started when it
Air pockets will make the guage do that, and also cause your heat to come and go. Also, a poor radiator, as in rotting, or plugged up, will cause high temperature issues.
Posted on Sep 20, 2011
Refrigerator malfunction
samsung units have duel cooling. that means there is a evaporator in the freezer and the fresh food section. it is possible that the temp sensor in the refrigerator section could be bad. and they have been known to have defrost problems there to. the samsung is a complicated unit and its hard to describe how to repair since there is a lot of electronics that control everything. the best thing I could say is to unplug the refrigerator for a few minuets. sometimes this will reset everything and start the unit back to the factory settings. if that does not work I would call for service. hope it helped you some
Aug 04, 2007 | Samsung RS2556 Side by Side Refrigerator
Water line keeps freezing on my GE side by side refigerator
Check to see if the water tank in the bottom of the refrigerator section is frozen. If it is, you will need to turn the refrigerator section temp down.
Dec 05, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridgidaire refrigerator flashing error code 4
From what I remember a flashing 4 means "damper error". Send your model number found inside or on the outside of the fresh food section, The air damper is found between the freezer and fresh food section and regulates temperature in the fresh food section by opening wide for things that warm up your fresh food section example would be opening the door and letting warm air inside . The damper then closes to keep the right temperature. If you have questions please ask, Thanks Sea Breeze
Sep 07, 2012 | Frigidaire Refrigerators
Our power went out due to the snow storm, and the display panel shows 88 on each side...how do I reset this...will this cause the fridge temp to go up?
From http://www.samsung.com/us/support/supportMain.do
Your refrigerator is equipped with an onboard diagnostic system. If the diagnostic system detects a fault, it will display a specific line segment on you refrigerators LED display. If your refrigerator is displaying an error code, please note the error code, and reset the refrigerator by unplugging the refrigerator for 30 seconds. When the refrigerator is plugged in, it performs a self diagnostic check of the various sensors and functions. If the error code reappears your refrigerator will require service. Please click the "Create Online Service Request" button below this article to initiate the service process. After a power outage the display panel may start blinking "88 88." If you unplug the unit for 30 seconds then plug it back in the display will return to normal operation after several hours. The power outage/surge can cause a communication error between the circuit boards in the unit. It can take several hours for these boards to stabilize.
If the display does not reset, go to the Samsung Support link above, enter your model number, and follow the prompts to request a service ticket.
Good luck, and if this helps, please rate my answer!
Feb 02, 2011 | Samsung Refrigerators
We have a Samsung side by side RS2534WW, just had a brief power outage during a storm, now 1 light on the panel blinks, nothing else. Lights are on inside the fridge, but won't deliver ice or do anything....
I simply press and hold the top left and top right buttons (which are for the temp in each section) for about 5 seconds to reset. It's fine until the next power failure...and I don't want that when I'm on vacation.........
Jun 29, 2010 | Samsung RS2534 Side by Side Refrigerator
Samsung RB1955SW refrigerator is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 07, 2010 | Samsung 18.8 Cu. Ft. Bottom-Mount...
I have model #RB1955SW A couple of times it didn't start on its own. I needed to unplug and then plug back in .Then it cooled back down. Is there a relay switch or something like it that should...
Replace the thermostat . The piece that the dial temperature adjustment is on . Cannot find the model number you gave , or I could give you the part number .
Oct 22, 2009 | Refrigerators
Error codes for Samsung Fridge
you need to check the refrigerator defrost sensor connection thats behid the light bulb in the middle of the refrigerator section
May 24, 2009 | Samsung RS2534 Side by Side Refrigerator
Power outage caused by fridge to quit
OUCH! , the partial digit display is an error code that has a meaning and they are never good , these units I have seen/repaired many times but I do not have the code book to determine it.
Try holding down the power freeze and power cool at the same time until you get something. If the unit is ok it will reset and hopefully be fine , if you still get a code these units have longer warranty's and could be repaired with no charge.
Phil
Apr 14, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
529 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
