Question about EliteGroup Computers & Internet
Usb ports not working. power is on but computer doesnt detect anything plugged in. win xp
    Novelist:
  • 129 Answers
Hi..
Did you try the other port of your motherboard. Do not use the front USB socket of your computer, you need to plug i directly to your motherboard ports. If the same things happen. you need troubleshooting.
usb ports not working. power is on but computer - moz-screenshot.pngTry uninstall and reinstall of usb drivers
Remove and reinstall all USB controllers
To remove and reinstall all USB controllers, follow these steps:
Click Start, click Run, type sysdm.cpl in the Open box, and then click OK.
Click the Hardware tab.
Click the Device Manager button.
Expand Universal Serial Bus controllers.
Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
Restart the computer, and then reinstall the USB controllers.
Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
ICmanServer
Posted on Jul 31, 2009
My computer don't see mt toshiba 500 GB external disk. I had Win XP with SP3 and my external disk is connected to a USB hub with 8 ports. I had a pen connected to that hub and the computer see it. But...
Your USB hub cannot provide enough power for your external hdd, you can try to plug it in directly to any free USB port for the mean time to check if its detected or not, if it has a power button ( which is not normal for regular USB powered EXT HDD) make sure that it is on, if its still not working try to use a different cable, a known good cable or plug it in to a different computer to check if its your USB port, or the usb cable or the ext hdd that is causing the issue
Hope this help.
Jul 10, 2011 | Toshiba (HDDR500E03A) 500 GB USB 2.0 Hard...
CyberShot DSCW55 driver wont work on win xp x64
No, their is not one if its not compatible you will have to purchase a camera that is compatible with win xp 64. Another option is to get a USB card reader ($15-$20) and put your memory stick inside it and goes directly into the usb port. You can pull your photos off just like a portable memory stick. I use this option for my Sony camera and my laptop has a media port that takes the card directly with no need to have a USB card reader....
Sep 26, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Hi, the CS62U is connected with an HP8750 (win2000) and a MSI WIND NETTOP 120 (win XP home). It works perfectly with the HP desktop but the mouse is not responding anymore.
Try this:
1. Disconnect your HP computer, so that only the MSI Wind is connected.
2. On the keyboard, hit [Numlock]+[-] then press [A] (this will auto-search for the computer that's connected, and connect both keyboard and mouse to that port).
Give XP a minute to detect new hardware. If XP does not detect the mouse, try plugging the mouse into a port directly on your netbook. If XP still does not detect the mouse, it's XP that's not detecting your mouse properly, not the kvm switch. :) If it does detect it, you should be able to then plug it back into your kvm switch and it should work at that point.
Note: if you get stuck with lights flashing on your keyboard, just hit [Esc] on the keyboard. That will reset the KVM switch.
Hope this helps!
Sep 24, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
MAXTOR 250 gb usb hard disk is not detected
On some computers the output power of the USB ports is too low to drive the Ext. HDD.
Have you tried other USB ports on your computer?
Get yourself a powered USB hub and try that, borrow one if possible, if that works get one for yourself....
Aug 21, 2009 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Seagate 1 TB not detectable on win 2003, xp detects it
As you know,the Seagate sometimes has the firmware problems,so it seems that this firmware designed only valid in XP or Vista system,you may find the firmware update from the seagate official website
Jun 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Usb port not working
try changing the settings in BIOS to high-speed USB speed support. Also physically clean the port of all dust(it happened to me and after washing it pure alcohol, the usb port started working)....sodeep
Apr 22, 2009 | Intel Motherboard
Usb Driver For Huawei SmartAx Mt882 for win XP professional
Windows XP Professional doesnt require USB Drivers, these Driver built in Windows XP professional
or there already present in ur system..........
so go ahead connect anything to ur usb port(like digital camera, mouse, pen dirve, flash driver , memory card reader,..portable harddisk , digital cameras)
when u insert any of the component(for eg: pen drive) in to the usb port OS will automatically detected these devices and install USB Drivers.... dont worry... about this  and be rest assured....OS will do the work for u...............
Thanking You
M. Sridhar
Dec 26, 2008 | Computers & Internet
Transcend 4gb pendrive not being detected in Win XP
Hi... Try this link. It may work. Iam busy a bit. So cant go thru ur problem thoroughly. If doesnt work, post back. http://www.usbman.com/Troubleshooter%20General.htm
Nov 13, 2008 | Transcend (589307) Media
Transcend 4gb pen drive not getting detected
pen drives generally have 3 to 5 years warranty, if your pen drives are not detectng on other systems also, its better to replace it
Jul 23, 2008 | Transcend (589307) Media
I-rocks IR-4300 4-Port USB Hub doesnt work
You shouldn't need a driver for it, Windows has bundled native drivers that will be enough to make it work.
Does anything else work in the port you plug the hub into?
Jul 11, 2008 | i-rocks IR-4300 4-Port USB Hub
Computers & Internet Logo
284 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
