Question about HP Pavilion dv9000t Notebook
Dead. Only lights up where plugged into power cable & LED lights
Otherwise totally dead, dead, dead...and way past the extended warranty. Was working when closed liad last - I moved (it was properly packed but sustained usual cross country vibrations in a truck) - Wondering if a power ribbon cable worked itself loose? Or the MB just died.
  • 1 more comment
  • abkahn Jul 31, 2009
    Looking inside everything seems in place - have not removed any boards. Only power ring lights up - no fan. All dead.
    Replace the P/S? You mean the external transformer? The battery? They are all fine. Recall the blue ring lights up when I plug in the transformer. IF you mean some form of P/S inside the case, I don't see anything other than the connection into the MB from the blue ring connector.
    Thank you for the advise. Still dead.
    President:
  • 1,335 Answers
Open up the case and make sure that all the PC boards are properly seated in their slots.
Check all the ;power connectors and board connectors. One of them may have come loose during transport.
Leave the case open and turn on the power to see if the fans (case and CPU) are spinning.
Let me know if this fixes the problem or if we have to further research the motherboard. Thanks.
Posted on Jul 31, 2009
  • Bob Kitaji Jul 31, 2009
    If you're not getting power anywhere I suspect that the power supply has died and need to be replaced. Pull the power supply, make sure you mark the connections so that you can quickly reconnect the new power supply. Take your old power supply to your local repair shop or computer store and purchase a power supply with the same dimensions as your old power supply. The wattage can be higher that your old ps.
    Reinstall the new ps.
    This should have you up and running.
    Let me know if this solves your problem. If it does please raise the solution rating. Thanks.
    OK.
    Try the following.
    1. Disconnect the AC adapter.
    2. Remove the battery.
    3. Press and hold the power button for 30 seconds to 1 minute.
    4. Reinstall the battery.
    5. Reconnect the AC adapter.
    6. Download and install the latest BIOS version for your model.
    ftp://ftp.hp.com/pub/softpaq/sp33501-34000/sp33832.exe
The unit appears to be dead but the green and yellow channel LED's continuously flicker.
I am guessing that the lights are near the network cable plug? This simply shows that there is a signal on the network cable that is plugged-in. The laptop may be dead. Is there a light on the power supply? If you remove the battery, plug the power in and press the power button, what happens?
Dec 15, 2012 | Computers & Internet
I have an lc45d40u and i have no pic and or led light on its black i do have power but don't know where to look thanks for all help
Tv only have LED power light indication is on and but have totally black screen?Yes.This problems are alway the causes of the tv Tuner signal board it is shorted and dead.That the board,where the incomming signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Feb 25, 2011 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Tv Wont turn on!
Check the power source?Yes,tv power LED light indication flashes or LED light indication totally dead?The tv power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 31, 2010 | Akai LCT3285TA 32 in. LCD Television
As it has become clear, there is a problem with Westinghouse SK-32H540S , burning or chemical smell. Is this an easy repair or total wash ?
What is the problems of the response of the tv?Tv power LED light indication flashes or totally dead?Or something else problems?If it is the tv power problems.The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 20, 2010 | Westinghouse 32" Flat Panel LCD HDTV
We can't turn on the TV. We[ve tried the remote & manual controls & have unplugged it & plugged it back in using both the surge protector and wall outlets to no avail... Any suggestions?
The power LED indication light flashes or totally dead?The power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacemrnt.
Oct 17, 2010 | Olevia LT42HVi 42 in. LCD Television
My DV6000 was hit by a power surge during a lightning storm. It is completely dead. no lights or any indications of power. I have multiple batteries and AC adapters so I know it is the laptop. Is there...
No, there is no fuse.
Is the manufacturer's warranty still valid?
Did you purchase the computer via a credit-card that "doubles" the warranty?
Did you purchase an "extended" warranty from the manufacturer, when you "registered" it?
Did you purchase an "extended" warranty from the retail store?
Otherwise, find the nearest authorized HP repair outlet, and get it fixed.
Nov 18, 2009 | HP Pavilion dv6000z Notebook
How to know if the monitor is totally dead?
Generally, if the power light (LED) doesn't come on and there is no screen display with or without input signal, it's dead. Probably a failed power supply.
Aug 29, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
What does the 50 amp fuse labeled batt in the fuse box under the hood send power too ? If I dont remove it my battery will drain totally dead over nite. Its in a 1996 chev 1/2 4wd Z71 extended cab
The fuse is the main fuse to the vehicles power supply just the same as removing the battery cable . you have a drain in your electrical system , use a test light , remove the possitive cable from the battery and hook one end to the battery and the other to the cable remove fuses till the light goes off ( make sure all doors are closed and switches turned off) that is your drain source . do no remove the 50 amp fuse in this test .
Aug 28, 2009 | 1996 Chevrolet K1500
Monitor is totally dead
Through my past experience I mwould remove the solder point at the input power B+ line to primary winding FBT. If the HOT has shorted there will be no power.Straight to the point if you know where the HOT is , you can desolder the middle pin or collector of the HOT transistor. If you desolder the pin which result the power led light turn up. That indicates either FBT or HOT has shorted
Apr 19, 2008 | LG Studioworks 45 14" CRT Monitor
Dead
You may have solved your own problem. It may well in fact be dead. Check the warranty status on your MP3 player and hope it is still in warranty. Otherwise, you might as well search for a new MP3 player. There is a chance the battery may be totally dead (possibly a leak) but this is incredibly rare. Since it's worthless as it is and if it is out of warranty, open her up and check the battery, if you notice a cable loose between the device and the battery, try reconnecting it. If you see the battery has leaked, get a replacement. Other than that, you'll need additional parts and patience which is beyond the worth of the MP3 player.
Sep 06, 2007 | SanDisk Sansa e250 MP3 Player
HP Pavilion dv9000t Notebook Logo
289 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
