Question about Dryers
Our dryer burner is not working. Drum turns, but no heat
  • tmustert Jul 31, 2009
    canbruce, thanks. i don't see a glow from the igniter. does that suggest a bad igniter and would i smell gas if it was the igniter? thanks. tim
    President:
  • 1,776 Answers
The problem is most likely the gas valve coils. If the ignitor is glowing, but the burner won't light, I would look at the coils. The gas valve coils are black electrical coils that are right above the gas valves. These solenoids, when energized, open the gas valves. When they go bad, the gas valves are not opened and the burner cannot ignite. They are hard to test and it is best to replace both (all) of them at the same time. Hope this helped and best wishes.
Posted on Jul 31, 2009
  • Bruce Canfield
    Bruce Canfield Jul 31, 2009
    If you smell gas, then the gas valve coils are operating, If the ignitor is not glowing, then the ignitor is faulty. It should glow visibly when operating correctly.
  • Bruce Canfield
    When the ignitor is working properly it will glow orange. If a gas dryer is tumbling, but will not heat up, it is because the ignitor cannot ignite the gas. The ignitor is usually held it place by a tension bracket and has two wires attached. They can be attached at the ignitor or at the bracket. Sometimes, the tension bracket will have to be replaced along with the ignitor.You should be up and running in no time!. Hope this helped and best wishes.
MAytag 2300 aww does not heat
If this is a gas dryer it may be the ignitor has failed. There should be a panel you can remove to inspect the burner compartment. Turn on the dryer and look for an orange glow if you don't see any glow the ignitor is probably faulty and should be replaced. If it is an electric dryer it may be a bad heating element. Hope this helps.
Jan 03, 2014 | Maytag Dryers
BURNER NOT COMING ON .DRUM IS TURNING .GAS IS ON .LOOKS LIKE NOT IGNITER HOW DO I CHANGE IGNITER?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 15, 2011 | Dryers
We get no heat from the dryer, drum turns. I want to know how to access the burner elements, including the igniter and sensor. Do I have to take the dryer all apart?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 24, 2010 | Dryers
Gas dryer, no flame in the burner , dryer turns on, drum turns, no heat.
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
May 07, 2010 | Dryers
Will not turn on. Drum will not turn, no heat
You probably have a bad thermal fuse , located on the heater box , with 2 white wires going to it . Once you have the top up , in the left rear , you should see the burner box . The 2 white wires go to the thermal fuse ( pt # LA1053 ) Depending on the model number of your dryer .
Aug 25, 2009 | Maytag Dryers
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
Dryer blowing & rolling but no heat
There should be a little white plug on the front of the dryer. (lower left) Take that out and start the dryer. IF your ignitor is working you will be able to see it turn red through the whole. If you dont change the ignitor. then it will light the burner.
Nov 18, 2008 | Whirlpool Dryers
Dryers Logo
98 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
