SOURCE: SAMSUNG split AC AS09WHWE led keeps blinking.
Samsung Air Conditioners SAMSUNG split AC AS09WHWE led keeps blinking
SOURCE: no heat. 1 slow blink from circuit board LED.
My thoughts were amateur. Paid a professional to corect the problem.
SOURCE: Free standing ice maker not functioning
Have you got a slow flash or fast flash?
A slow flash is a problem with the sensor.
A fast flash is dirty condenser failed condenser fan.
See page 16
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Thanks for your suggestion"
SOURCE: Insignia ns-pdp50hd-09 plasma hdtv will
Yes it is definitely a power supply board issue. The self-diagnostic error codes of the LEDs are self descriptive. The logic board led blinks when an OVP(OVer VOltage Protection) is detected and the LED then blinks on the source of the problem(power board). My money would be on failed voltage regulator ICs and/or blown resistors. If you are not good at component level repair, then it might be good idea to just replace the board.
SOURCE: Insignia ns-pdp50hd-09 plasma hdtv will not power
Hi red, My name is John. Welcome to FixYa. Go back and check your plugin connections. Make sure that they are making a good connection, some can be hard to make contact.....John
