Tablets & eReaders Logo
D
Dorothy parker Posted on Feb 21, 2018
I have lots of photos on my iPad but they will not download to my computer, why
I am unable to download my photos from my iPad to any computers, I tried 3 today at a computer shop, only showed a maximum of 30 photos but lots more on iPad. Any ideas
Try downloading in small batches,may take longer ,some pcs cant recognise large quantities on loading so they time out, also try sendig via blue tooth after making sure both units are compatible and connected.
2answers
After connecting my ipad air to computer, the itunes can't recognize it. what happend? i want to transfer photos to ipad. please help.
iTunes should sync your computer with your iPad but sometimes it acts funny. Don't know why, but it does. So if you cant get it to sync, try Copy Trans Manager. It is a FREE application and it should let to manage the content of your iPad without iTunes. Actually, it uses some files of iTunes as a drives. Be caredul with Softonic's downloader. Use custom mode, go for Copy Trans Mnager and uncheck or skip anything elese offered free.
1helpful
4answers
Transfer photos from my PC to my ipad mini. I have tried iTunes but I don't understand it
Try downloading an app called Shareit.
When attached to the same WiFi, you can transfer Photos directly from iPad to iPad and even between Windows and Andriod devices. You start Shareit on both devices and send from one and receive on the other.
Other applications won't run says storage full
you may want to check and make sure you didn't run out of space on your iPad. To do so connect your ipad to your computer using the usb cable and open up iTunes. Once connected and open look on the top right side of the itunes window and you should see a "ipad mini" tab. click on that and it should give you all sorts of info about your ipad mini. look on the bottom of that window and see how much/many "GB FREE" yours show. if your ipad mini is full its time to delete some of the apps you don't use. Also import photos to your computer to free up a lot of space on your iPad. In my experience photos, music, and movies take up a lot of space
5helpful
4answers
How to delete photos from the Ipad
If to have the iPad before the camera was added, you have the original iPad. If you synced the photos from your computer, you have to delete the photos by syncing with iTunes again, but you have to "uncheck" the albums or folders that you want to remove.
1.Connect the iPad to the computer and launch iTunes.
2.Click on the iPad name on the left side under devices.
3.Click on the Photos Tab on the right.
4.Uncheck all of the albums or folders that you want to delete from the iPad under the Sync Photos from heading.
5.If you want to delete all of the photos - uncheck the Sync Photos From heading
6.Click on Apply in the lower right corner of iTunes
Done.
If it can't work, you can refer to the article about Delete photos from iPad.
Good Luck!
2helpful
6answers
Copy photos from PC to Ipad
Connect your iPad to your PC. Start iTunes. In the left column of iTunes on your PC you should see your iPad listsxed. Select your iPad. Look for photos in the bar at the top of the right column in iTunes on your PC.
For more detailed guide of transferring photos from PC to iPad, follow this tip "Copy files from Computer to iPad".
6helpful
2answers
How do I download photos from my laptop (Toshiba Satellite) to my ipad?
To transfer photos from your Toshiba laptop to your iPad:
Step 1: Connect your iPad to your Toshiba laptop using the USB data cable that came with your iPad.
Download Install and run iTunes and select your iPad device from left panel under "Devices" section.
Step 2: Click on Photos tab, Check the "Sync Photos from" checkbox and select "Choose Folder..." option from drop-down menu. Locate the folder with the photos you want to transfer on your computer and hit "Select Folder" button.
Step 3: When folder listed in iTunes, select all pictures that you want to copy to your iPad and hit Sync/Apply button from bottom right corner.
3helpful
9answers
I want to transfer my pics from my computer to my I Pad but doing it by Email is slow, is there a better way?
Follow the steps to transfer pics from your computer to your iPad:
Step 1: Connect your iPad to your computer using the USB data cable that came with your iPad.
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
