Question about Hoover Washing Machines
Hoover 210 A6952 washing machine... one loose wire at timer.
Does anyone have a wiring diagram for a Hoover 210 A6952 washing machine? I replaced a broken tube for the pressure sensor, and a wire came off - it is the yellow wire coming from the motor connector going to the mechanical timer, I am unable to see the spade terminal where it came from. The timer is a 47578-K78 if that's any help. It's a great machine and I dare not risk damaging it trying random terminals, and don't want to throw it out.
    Sergeant:
  • 190 Answers
If you email Hoover with your product details & the timer details as above they can have an engineer contact you via email or phone, or most have an online live chat service which has engineers who can answer your problem in minutes.. Truly hope this helps & your problems are soon resolved..
ps you could google the part number & find images on the item that will show you the wires in situ, this may solve the issue for you as well...
Posted on Feb 21, 2018
Testimonial: "Thanks. By chasing through Hoover -> Electrolux -> local parts dealer I was able to get a wiring diagram. (Extensive searches on google using model #, timer # revealed nothing.) Now the motor worked for a bit in one direction only and then seemed to overheat... so on to other problems..."
Oceti
  • 51 Answers
SOURCE: Washing Machine Motor Missing Wire Harness
Go to www.repairclinic.com and order the complete wire harness and cap.
Easy place to do business.
Posted on Jan 23, 2008
SearsTechToo
  • 261 Answers
SOURCE: GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Posted on Oct 03, 2008
mohammed387
  • 1952 Answers
SOURCE: washer will not drain water or go into rinse and spin cycle
First thin I would try is to check your thermal fuse for continuity. Its located on the tunnel that incases the heasting element.
Try putting the machine into diagnostic mode. If it won't enter diagnostic mode, then you need to replace the main control board.
You also want to check the drain hose, the end of the hose is tapperd and tends to collect lint. Run a coat hanger up the hose and see if you can fish something out also check that belt.
Posted on Oct 06, 2008
louislevel_2
  • 374 Answers
SOURCE: Wiring a Husky brand compressor from Home Depot.
hi! there,
you can use terminal connector like on figures83ba8af.jpg joint connector or lug connector
this are more convenient to use
easy to install and has insulated for connection.
insulated ring terminal connector
this is also good for connector more safe for circuit breaker suipply.
go to the nearest hardware or mall
Posted on Apr 20, 2009
gotgeek2
  • 565 Answers
SOURCE: Need wiring diagram for Intermatic 240V Mechanical Time Switch
For anyone else who may be reading this post, these instructions are for the T104 ONLY.
Connect your incoming line) 240 volt wires to terminals #1 and 3. Connect the outgoing 240 volt (load) wires to terminals # 2 and 4. Don't forget to connect both equipment ground wires (bare or green) to the "GR" terminal.
Do NOT connect anything to the "A" terminal.
Posted on May 09, 2009
Hoover 210 Heavy Duty Washing Machine timer grinding and vibrating...how easy is it to replace?
Make sure you have the right replacement part when you try to replace it. Take a picture from all angles before you disconnect anything. label each wire along with a sequence starting from a reference point. Double check. Then start to remove wires from the timer. Remove the timer and fit the new one. Replace all connections using the labels you placed. Double check with reference to the pictures.
Jan 10, 2014 | Washing Machines
My hoover washing machine top load won't start. I have checked the power from the wire going to the timer.The door latch switch is working and still it won't start.
my hoover washing machine do not stop they show 1 min left . i was try serval time the happend is same and inside few water as well
May 26, 2011 | Hoover HTC243 Top Load Washer
750L 1AUS top loader Hoover washing machine washes (agitates) and rinses but will not spin. Can hear the sound of the pump
First unplug the machne,there are 3 wires that goes to the motor,put the machine on its side and inspect that none of them have a break or came loose from its wire terminal.Good luck Giselle Dosen,have a great day !
May 16, 2011 | Hoover Washing Machines
Stop working during a wash cycle, power was at the plug
ince the washer is stopping during the fill, wash and rinse cycles, it is possible that you have a failed timer. A loose wiring connection could also cause this problem. Before replacing the timer, I recommend that you unplug the washer and check the wiring connections on the timer for a loose wire. Check the wiring connections on the water level pressure switch as well.
Jan 12, 2011 | Whirlpool Washing Machines
Replace Timer Assembly on GE WJRR1470E1WW Washing Machine
Servicing the Timer
Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.
In the next section, we will examine two of the most crucial elements of a washing machine -- the water inlet valves and the agitator.
Apr 09, 2009 | Frigidaire FWS833A Top Load Washer
I need to know how to replace the timer-mall on my Amana washing machine model #ALW780QAC
hi here steps Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Sep 12, 2008 | Amana Washing Machines
WIRING DIAGRAM FOR A FRONT LOADER WASHING MACHINE
go to macspares.co.za
They have couple of diagrams
Aug 13, 2008 | Washing Machines
Hoover Elite 1205 washing machine
Does an Hoover elite 920 gearbox fit the hoover elite 1205 thanks
Sep 18, 2007 | Washing Machines
Hoover 700LB top loading washing machine
there should be a wiring diagram on board in an envelope or taped somewhere you can get one from sears too
Dec 09, 2006 | Hoover HTC243 Top Load Washer
Washing Machines Logo
827 people viewed this question
Top Hoover Washing Machines Experts
shaun taylor
Hjalmer Lamminen
Hjalmer Lamminen
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
