Question about Maytag Atlantis MDE7400AY Electric Dryer
Stains on Maytag dryer drum
The dryer drum on our fairly new Maytag dryer appears to be staining. Or could it be that the finish on the drum is wearing off? Any help would be appreciated.
  • greensidegal Dec 21, 2007
    Thanks for replying, Bob. By 'blue glass cleaner'...I assume you mean Windex? We'll give that a go! Again, thanks.
  • 833 Answers
This may be caused by some kind of wash product or softener product. You may be using too much. You can use a blue glass cleaner or small amounts of mild abrasive cleaner and water to try to remove it. Drums are made of porcelain or stainless steel and should 'never' wear out.
Posted on Dec 21, 2007
  • Robert Hirst Dec 21, 2007
    Yeah, that might work. If you run into a real problem, a little WD 40 on a rag...followed by soap and water will also dissolve almost anything. There are a couple of these issues...wonder why only this model. Good luck.
I used WD40 then Bar Keepers for that mild abrasive and it worked! I had a dungaree blue stain in there for the past 5 years. It's gone now. Thanks!
Posted on Mar 17, 2009
My dryer is leaving rust stains on my clothes
you needto replace your dry drum .
Sep 30, 2015 | GE Dryers
How to remove ink stains from dryer drum?
Try using EZ off oven cleaner. Spray on and let sit for an hour. Should take most if not all ink off
Jul 21, 2014 | Maytag Neptune MDG5500AW Gas Dryer
Gas dryer yellow stains
Check inside your drum for a crayon stuck to it
Dec 04, 2017 | GE Profile DPSB620GCWW Gas Dryer
Brown stains in the drum of my whirlpool dryer
Apparently a common problem with 4-5 year old Kenmore and Whirlpool dryers. The paint is rubbed off the back panel by the felt seal attached to the rotating drum. The bare metal gets rusty from the damp clothes. The rust is rubbed off by the felt seal. The entire felt seal will turn brown. The stains are transfered to the clothes. The rust stains can generally be removed by additional cleaning.
I'm going to replace the felt seal on the drum, clean the rust off the back panel and see how long it lasts. Seal w/ adhesive is $30-40.
Some have suggested painting the back panel, but i don't think fresh paint is going to last long. The original paint was probably electrostatically applied and maybe baked on.
Nov 05, 2009 | Dryers
Rust stains on clothing
Cleaned lint out of the dryer internal air ducts.
Replaced the upper and lower drum seals.
Aug 23, 2009 | Frigidaire Dryers
Black stains on white dress shirts
The rollers, guides, or wheels that are used to support the clothes drum may be worn out. When this happens, it may cause the drum to drop down slightly in the front or rear. Clothes can get caught between the front or rear of the drum and the dryer interior. This can cause clothing to have marks and/or tears. Check out the rollers, guides, and wheels for excessive wear or damage. Sure hope this helped ya!
Jul 20, 2009 | Whirlpool WGD5900S Gas Dryer
Clothes coming out of dryer with oil stains
Some thing was put in there with it on them you just need to clean it out thank you for useing fixya rate me
Apr 07, 2009 | Maytag Atlantis MDE5000 Electric Dryer
My maytag neptune dryer seems to be leavin blue stains
you can scrub it out with bleach it will get rid of most of the staining
Jan 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dark stains on some clothes after drying
I had this same problem. I turned out to be the seal around the drum. You have to remove the drum and put in another seal. Not real hard to do. You can order the seal from sears and I think the glue came with it. Just have to remove the lint vent screws and then the top lifts off. then remove the screws to the front panel. Hold the drum because it will fall. Unhook the belt. Remember how it connects. Then take the drum off and remove the seal and as much leftover glue and fabric. Glue the new seal on and let dry. I did overnight. It should have directions. then replace everything. just make the seal is on the same way you took it off so look at everthing before you remove anything. Once the seal was replaced no more stains.
Nov 21, 2008 | Kenmore 65924 Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
542 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
