Question about Goldstar KG6000R Window Air Conditioner
Window Air Conditioner Sound/Vibration
Every couple minutes or so the air conditioner makes a "thunk" and it vibrates a little at the same time. Its not superloud but it does get annoying when trying to sleep.
The filter on the front is clean. What else can I do?
    Champion:
  • 233 Answers
It sounds like the compressor may be "Short cycling" (turning on and off too quickly) if it is the compressor doing this there may be a problem with the termostat, the charge on the system, or the compressor itself. If it seems to be cooling correctly you may need to add a brecket to the unit outside or add some rubber or sound absorbing material between the unit and the window sill. hope this helps
Posted on Jul 31, 2009
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
Hi, my air conditioner sounds like a truck, can you help me?
need more info is the noise outside or inside? try to describe the noise ie does it sound like a fan hitting something or lots of vibration? etc get back to me
Aug 14, 2011 | Amana PTH073E35 Air Conditioner
I have a frederick x star Its a wall mounted unit and is excessively noisy at the beginning of a cycle or start up it does not appear to be loose in its mounting though why is it making the noise
This often happens when units get a little age on them. But, they quiet down after 30 seconds or so. Be sure the unit is tightly secure in the window, as the vibration my be caused in part by the unit moving slightly in the window.
Hope this helps you and thanks for choosing FixYa.
Jul 28, 2011 | Friedrich XStar XQ06J10 Air Conditioner
I just purchased this portable air conditioner. I have a few questions about its operation and intimation. First, my window is a vertical sliding window that is about 55u inches tall. Do u have anything...
LG does not currently have an extender panel. However, call Vance Baldwin/Encompass at 1-866-779-7906, as they may can help you with that.
As far as noise is concerned: Generally speaking, most noises heard from the air conditioner are normal sounds of operation. Most of the time, noises are muffled during the day by activity in the home, but heard at night when it is more quiet.
Vibrating Noise? This is most likely the result of improper installation. Check that the unit is secured properly in the unit. Make sure the filter and the front grille are attached properly.
Hissing/Gurgling Noise? At the ON/OFF operation is caused by the refrigerant flowing inside the air conditioners sealed system. THIS IS NORMAL. This sound is a little louder for 2~3 minutes when the unit is first turned on. This is the sound of the compressor start-up. THIS IS NORMAL.
Beeping sound when control settings are selected/changed? THIS IS NORMAL. This noise is a signal that the control panel settings have been changed.
Pinging Noise? THIS IS NORMAL. This is the result of moisture in the base pan being picked up by the fan (called a slinger fan) and thrown against the condenser. This helps to discharge the heat and make the unit cool more efficiently.
Is the unit installed in an enclosed are? A unit enclosed by many walls is likely to produce more noise as the sound waves will be reflected and echoed.
Once the room temperature is met, the compressor should turn off automatically. But, the fan may run for several more minutes.
I hope this helped you. Thanks for choosing FixYa.
Jul 24, 2011 | LG LP0910WNR Air Conditioner
Just installed a new Friedrich CP06C10 window air conditioner that I purchased from J&R. Turned it on and it makes a loud rattling sound. I installed a Friedrich CP08C10 window air conditioner in...
its the fan hitting the shroud, look inside for the fan hitting anything and check for the copper lines vibrating against each other, also, it could be the plastic front vibrating, put your hand on the front to see if you can stop it,
Apr 17, 2011 | Friedrich CP06C10 Wall/Window Air...
Air conditioner compressor vibration
bearing in ac pulley is faulty
Nov 03, 2009 | 2002 GMC Yukon XL
Bad vibration and noise suddenly in a 5 month old air conditioner
please make sure this vibration not from the unit fixation if ok check the fan may be brockenor blower
Sep 16, 2009 | Kenmore 76081 Wall/Window Air Conditioner
Way too loud
it is prob. a pipe vibration, window unit are not knowen for quiet running
May 02, 2009 | Goldstar KG6000R Window Air Conditioner
Mastercool air conditioner
If it is indeed a true vibration, it could be a number of things. I have seen bad bearings do this off and on as the cooler runs. Could be something going wrong with the blower motor. There are several things that need to be checked to properly evaluate the problem you are describing.
Aug 29, 2008 | Mastercool 67680 Evaporative Cooler Air...
Loud as Hell
Is it installed in a window? Check to make sure it is installed correctly. usually there is a felt or foam strip that is used to dampen vibration when you place it in the window. It also acts as seal to keep outside air and bugs out. If you place your hand at various locations on the unit does the sound go away? If it does then you know it is a vibration problem. Just add new foam or re-adjust the foam or gasketing it already has. If that doesn't work then try to locate the source of the noise. Use a mechanics stethoscope or even a cardboard tube from paper towels will work. Once you have located the source then you can tell the store what the problem is when you take it back and get a new one. Cheap air conditioners are noisy. Some more than others, it's why they are cheap. But your problem does sound like it could be a product issue.
Sep 25, 2007 | Haier Mechanical Air Conditioner HWF05XC7
Goldstar KG6000R Window Air Conditioner Logo
280 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
