Question about Emerson MS3111M Shelf System
Cd player problem
All three cd players have bad static in playing a cd. Doesn't matter how loud or what eq setting it is on. Doesn't do it on radio.....
From your brief description it sounds like there is a faulty component in the CD detector and pre amp section of the CD side of your sound system.
The Radio has its own separate Radio Frequency detecter circuitry and pre amp section so thats why the radio is OK.
There is no quick fix until the CD section can be inspected and the item causing the fault replaced..
Cheers From YUBEUT..
Posted on Nov 24, 2007
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
Dvd player just ticks and doesn't register a dvd
1.The DVD Drive makes two-three times noise than stop spin the media CD or DVD.
-Bad DVDRW Drive.
2 The drive does spin CD-DVD but doesn't load.
-. Bad NDMi PCB VEP79180 or VJB79180
3. Drive spinning but don't load CD or DVD
More chance Bad Drive or Problem with drive PCB.
Open top Cover of drive, open tray, close tray.
If laser flashed but doesn't play CD-DVD more chance bad drive PCB
Nov 23, 2012 | Panasonic DMR-EZ485VK DVD Recorder/VCR
I have a GR-470 EQ. I don't think I'm connecting
The proper sequence to eq just your CD player is, CD out to EQ in, EQ out to receiver in.
Jan 16, 2010 | Pioneer GR-470 Home Equalizer
Loud noise when trying to set to record or to play the noise is like loud static and I have to turn off both the TV and the DVD player to get it to stop the noise  I suspect it is the control
When you hear the static, turn power off and then back on again and it will go away. Some players have been know to do that. It is a problem with the programming. Just turn power off and right back on again and it should be fine.
Aug 06, 2009 | Televison & Video
Yamaha Natural Sound Amp and Tape Player
All of this applies to nearly any analog consumer audio gear...
If you have any Tape Deck and an Equalizer and only the one Tape Monitor loop you should place the EQ into that Tape Monitor loop, then place the Tape Deck onto one of the probable two Tape Monitors on the EQ as it sounds like you had here...
"When I had it set up with the graphic equaliser,pressing tape monitor on the amp and on the equaliser gave me play backfrom the tape player."
That setup will allow you to apply EQ to any analog source and the tape deck in record or playback mode.
However, if you want to remove the EQ and use the Tape Deck directly on the Tape Monitor just attach the deck's Playback cables to Tape Mon In (Play) and the deck's Record cables to the Tape Mon Out (Rec). Flip the Tape Mon control to hear the tape deck or monitor it while recording.
NEVER plug anything but a turntable into the Phono. It has a preamp that expects a ver ysmall signal from the cartridge AND it also has a severe RIAA Equalization curve which would result in grossly exaggerated frequency extremes if you managedto get a non-LP source into it. Likewise, turntables without internal electronics mut always use the Phono section of a receiver, preamp or integrated amp to get the boost and EQ they need.
Mar 23, 2008 | Yamaha RX-Z1 Receiver
Audio settings
set your eq to flat. start from there. play at normal listening volume. listen to something that has moderate loudness.. i.e. jazz or lite rock music.. then slowly adjust to your taste.
Feb 15, 2008 | Pioneer DEH-P6800MP CD Player
Sherwood 460 equalizer hook up
Connect the EQ to the Sherwood as if it were a tape deck: EQ's outs connect to receiver's tape ins (play) and EQ's ins connect to receiver's tape outs (record).
Then you hook the tape deck up to the tape ins and outs on the EQ: Tape deck outs connect to EQ's tape ins (play) and tape deck ins connect to EQ's tape outs (record).
This will put the EQ in your receiver's tape loop.
The CD player should be connected to the receiver though the CD in's and out's (or if your Sherwood doesn't have a CD in/out, then use AUX or TAPE2).
To hear the EQed signal with all receiver sources (like the CD player) you'll need to engage the 'Tape Monitor' button or switch which will route the tape loop to the speakers.
Jan 09, 2008 | Audio Players & Recorders
How to connect eq to audio amp
To EQ all audio sources you'll need to have a receiver/amp with either a tape monitor loop or a pre amp-in/main-out loop. Look for a button on the front labelled 'Tape Mon' or ins and outs on the back labelled pre amp-out/main-in. If you have these you can connect the outs from the amp to the ins on your EQ and then EQ outs go back into the amps ins. If you have a tape deck as well, the EQ's 'tape mon' jacks replace the ones it takes up on the amp, so just plug your tape deck in here.
Just remember that whether you have a tape deck or not, if you hang an EQ off the 'tape mon' loop you'll have to engage the 'tape mon' button/switch for playback with EQ.
If your amp doesn't have these loops you can still use EQ but you may be restriced to one audio component source. So say you wanted to EQ the playback from your CD player, you'd just connect the CD players output into the EQs input, then connect the EQ's output into the amplifiers input (for CD player). Then everything you play through the CD player will be EQ'd.
Jan 01, 2008 | Audio Players & Recorders
download the newest firmware it will have custom eq =)
Feb 15, 2007 | SanDisk Sansa e250 MP3 Player
Emerson MS3111M Shelf System Logo
113 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
